Shorted Out Stepper Drivers
Posted by jaeg
January 03, 2014 01:36PM
So I just shorted out the GND of one stepper driver against the +12 of another stepper driver. It arced and the Arduino smoked leaving the TX and RX lights stuck on. So I know I'll have to get another Arduino but is there a way to test if I need to replace the RAMPS board or the stepper drivers?
Re: Shorted Out Stepper Drivers
January 03, 2014 03:28PM
Remove the RAMPS board from the Arduino.
Power up the Arduino via the USB and see if it works.
If not, you'll have to replace it.
If it does work, chances is you shorted the D2 Diode on the RAMPS board, which will have to be replaced.
January 03, 2014 03:38PM
Yah the Arduino board is shot. The RX and TX lights both stayed on and the Arduino IDE did not recognize it.
Is there a test to see if the RAMPS board/Stepper driver is damaged as well?
January 03, 2014 09:45PM
Just a question, how did you short them? I have a ceramics screwdriver for configuring the voltage so I can never short it with that screwdriver, just a tip smiling smiley
January 03, 2014 09:54PM
I shorted it trying to measure the wiper voltage while trying to calibrate the stepper motors. My twitched with my probe touching a ground pin and it bridged the driver right next to it's +12 input. Let out a nice arc and the Arduino smoked.
EDIT
Did some tests on the Arduino board. It seems the regulator is what fried. Does that meant the RAMPS board is probably OK?
Edited 1 time(s). Last edit at 01/03/2014 10:37PM by jaeg.
January 06, 2014 08:18PM
There is very little on the Ramps that can fry. The diodes are about the only thing you are likely to have nuked. The stepper modules can indeed fry and they should be checked one at a time.
January 06, 2014 08:40PM
I ended up ordering a new RAMPS board and stepper drivers with my Arduino just in case they do turn out to be bad.
What is the best way to test the old RAMPS board and stepper drivers and minimizing risk to the new Arduino board?
