How to Send G-code to RAMPS 1.4
Posted by jpan
January 22, 2014 10:54AM
Hi guys
I am using repetiter-host and printrun sometimes to operate my Mendel i2. Unfortunately, when I wanted to see my parameters from EEPROM using gcode m501, it didn't respond. Neither repetiter nor printrun worked.
Why?
Thanks.
Re: How to Send G-code to RAMPS 1.4
January 22, 2014 03:07PM
I think M501 only loads settings from the eeprom, i dont think it returns them over serial
January 23, 2014 10:59PM
Well but it DID return with my old printrboard... The motors moved all right so the RAMPS probably has received the code.
January 24, 2014 12:50AM
It doesn't matter which board you use. Whether or not there is a returned result depends on the firmware you are running.
January 24, 2014 02:55AM
m503 displays current eeprom settings. If its enabled in firmware
[reprap.org]
January 24, 2014 09:28AM
OK, I don't think in my firmware it's allowed. So how can I read that?
Thanks
January 24, 2014 06:20PM
So, can I actually send m92 code and m500 save to set my machine? m503 didn't let the computer display the printer's setting, am I still able to send g code?
