RAMPS1.4 stop January 23, 2014 12:30PM |
Re: RAMPS1.4 stop January 24, 2014 03:21AM |
Re: RAMPS1.4 stop January 24, 2014 08:52AM |
Re: RAMPS1.4 stop January 24, 2014 01:21PM |
Re: RAMPS1.4 stop January 24, 2014 08:00PM |
Re: RAMPS1.4 stop January 25, 2014 12:46AM |
Re: RAMPS1.4 stop January 25, 2014 01:53PM |
Cefiar
3. If you're using external drivers, you can break the "Enable" line to the motors (eg: with a a multi-pole switch and a bunch of resistors) so the steppers are disabled when you hit the switch. This is not the simplest thing to do and you'd want to be fairly good with electronics or know someone who is to help you. You could technically also do it with with the on-board drivers, but you need to cut a lot of tracks and run a lot of wires away from the board to your cut-off circuit.
Re: RAMPS1.4 stop January 26, 2014 12:24AM |
Re: RAMPS1.4 stop January 26, 2014 02:35AM |
Re: RAMPS1.4 stop January 26, 2014 03:27AM |
Re: RAMPS1.4 stop January 26, 2014 09:18AM |
cozmicray
I am resigned to the fact that RAMPS just doesn't support a STOP function
Just like you can't flush the commands built up
Hey coders and electronic hackers out there come up with a fix.
Re: RAMPS1.4 stop January 26, 2014 11:24AM |
Cefiar
Yes a PSU switch will do this, but you need to make sure that the switch you use is capable. Most of the cheaper E-Stop switches are not really designed for either high current DC or mains AC.
You really want to kill the DC side of the PSU (completely disconnect it), as the PSU will take a small time to shut down if you disconnect the AC side. If you're using RAMPS, you at least could put it on the 5A only side (motors and hot end), so you only have 5A to contend with. If you want to disconnect both the motors, hot end and the heated bed, you need to worry about 16A.
The main issue is that with large currents, the switch may actually fuse shut if you try and open it with lots of current going through it. The "arc" as it tries to disconnect gets hot enough to melt the plastic or even the metal of the contacts, rendering the switch damaged in some way. If it's damaged but permanently open, it's safe but annoying if you have to replace the fuse every 3-4 uses (example numbers only). If it ends up fused shut, then it's not doing it's job.
Re: RAMPS1.4 stop January 27, 2014 01:01AM |
cat.farmer
Cefiar
With that argument, i should be fearful of every switch i own. I have a power switch on my mains, correctly rated of course, and yes there is a short delay in shutdown, but i don't need a big red button, that says push me incase of disaster, i know my machine, i know where the switch is, and if something happens, i know how to use it. There are plenty of properly rated big red switches that would work.
I agree a kill switch is needed, but over complicating it only leads to more problems for those who don't understand how it works(internally), and most likely a long rewrite of the software.
Re: RAMPS1.4 stop January 27, 2014 01:33PM |
Re: RAMPS1.4 stop January 27, 2014 02:37PM |
Re: RAMPS1.4 stop January 27, 2014 06:23PM |
Re: RAMPS1.4 stop January 27, 2014 07:03PM |
Re: RAMPS1.4 stop March 03, 2018 12:35PM |
Re: RAMPS1.4 stop March 04, 2018 03:49AM |
Re: RAMPS1.4 stop March 30, 2018 05:38PM |
Re: RAMPS1.4 stop March 30, 2018 06:27PM |
