Extruders no longer heating up
Posted by Evil Monkey
February 10, 2014 01:12PM
Out of the blue, my RAMPS 1.4 stopped heating up the hot end. Nothing has been changed recently, thermistors are reading correctly, bed heats up etc, but the hot end cartridge transistors no longer turn on. What could be the cause of this?
Re: Extruders no longer heating up
February 12, 2014 03:21AM
Check wiring and maybe check your heater on the extruder. im using a resistor and it gets destroyed alot(because of too low resistance and i dont think its designed for high temp) so i keep replacing it and works afterwards.
February 12, 2014 12:06PM
Yeah, check the wiring. Did something come loose?
February 13, 2014 10:48PM
Switch the heater on and check there is 12v across the D10 connector - if there is, check that the hotend resistor itself has 12v dropped across it. If it has, replace the resistor. If no voltage anywhere, then we need to look at the control circuitry.
_______________________________________
Waitaki 3D Printer
