Welcome!
Log In
Create A New Profile
Home
Electronics Folder
RAMPS Electronics
> Topic
Heated bed works with test code but not Marlin/Repetier
Posted by
MarkR
Forum List
Message List
New Topic
MarkR
February 15, 2014 06:27AM
So the problem's not with the bed, and most likely not with RAMPS 1.4, is there some sort of firmware tweak?
Reply
Cefiar
Re: Heated bed works with test code but not Marlin/Repetier
February 15, 2014 06:36AM
Are your hot end and your heated bed thermistors working? Marlin won't allow you to heat up the bed unless both work.
Reply
MarkR
February 15, 2014 09:56AM
SOLVED! Turns out it was a dodgy thermistor, thanks!
Reply
Newer Topic
Older Topic
Print View
RSS
