Garble... on lcd, has anyone seen this before?
April 07, 2014 09:43AM
I am getting strange stuff on my lcd this morming.
this is visible while I am printing, the... stuff... changes shape as if it is updating during the print ???
y.
Re: Garble... on lcd, has anyone seen this before?
April 07, 2014 07:20PM
Did you recently extend the connecting cables?????
April 08, 2014 04:42AM
No standard flat pair that came with the package.
April 08, 2014 05:45AM
My guess would be either crosstalk from another cable running near the ribbon cables, or possibly a pin in one of the ribbon cables not making perfect contact. Try re-seating the cables first.....
April 08, 2014 10:36AM
Yes ! it worked. thanks.
12v power cable for one of the arduino cooling fans was near the sd cable. removing it solved the garble.
Still having trouble with connection loss between the pc and the printer...
April 08, 2014 03:44PM
This is an old and much discussed problem. Most people attribute it to static, but I'm not entirely convinced.
I don't know what you're running, but I have marlin on my printer. Either ejecting or inserting the SD card will reinitialize the display. Other than that, you seem to already be trying the logical things - shorter, higher quality, shielded cable, etc. Don't know what else to try.
