Problem with Mosfets on RAMPS 1.4 board
Posted by doniboy
Re: Problem with Mosfets on RAMPS 1.4 board
April 24, 2014 05:00AM
No, you just didn't give the right command.
M106 P0 S255 <- Turns on the FIRST fan
M106 P1 S255 <- Turns on the SECOND fan
Notes:
If you leave out the P command, P0 is ASSUMED.
If you leave out the S command, S255 is ASSUMED.
To turn off fans, you should use S0, so:
M106 P0 S0 <- Turns off the FIRST fan
M106 P1 S0 <- Turns off the SECOND fan
April 24, 2014 07:25AM
Thanks for that Cefiar - I wasn't aware of that command. The previous problem though, was with board 35,which was switching the D8 output when the hot-end (D10) was commanded? Any ideas?
_______________________________________
Waitaki 3D Printer
April 24, 2014 09:17AM
hey thanks for that command it will help a lot smiling smiley
I found this in the pin.h:
  #if MOTHERBOARD == 35
    #define CONTROLLERFAN_PIN  10 //Pin used for the fan to cool controller
  #endif
    #define HEATER_0_PIN       8
  #else
    #define HEATER_0_PIN       10   // EXTRUDER 1
  #endif
so it says that pin 8 (D8) is the HEATER or hot-end and pin 10 (D10) is a fan.
But I don't hink that is matters much if I use D8 for my hot-end instaid of D10, or will it?
As far as I can see the only difference is that D8 is on the second 12v supply and the MFR1100 fuse while D10 uses the 'normal' 12V supply and the MFR500 fuse.
April 24, 2014 07:34PM
Well that explains a lot! Should be ok I would think - you are not using a heatbed anyway. Glad you spotted that in pins,- I don't use Marlin,so wouldn't have known about it.
Waitaki 3D Printer
April 24, 2014 11:30PM
It will work, and in some ways it makes a bit more sense.
D8 can handle a lot of current (up to 11A), whereas D9 and D10 are both lower current (they share the power with the motors on a 5A circuit).
Since out of 2 fans and the hot end, the hot end draws the most current, it makes sense to put it on the output that can supply the most current.
April 25, 2014 04:02AM
that's what I thought!
I'm going to reflash the firmware on my MEGA and see if it works.
April 25, 2014 06:51AM
You'll be printing this weekend! smiling smiley
Waitaki 3D Printer
April 29, 2014 01:33PM
hey,
I flashed the new firmware onto my arduino and now D8 is the hot-end again and D9 is a fan.
But I tried the command that Cefiar gave but it doesn't work confused smiley
I used this command:
M106 P0 S255
M106 P1 S255
Of course separate and not both commands at the same time.
So my question is: How DO I turn on the second fan?
I was also wondering how and if I can add or change the commands so that I can create my own command for turning on the second fan, a.k.a. D10
April 29, 2014 02:15PM
update:
I just went looking into the firmware and found out that D10 turns on when the motors go on for a period of time.
so when the motors move, the fan turns on and blows onto the steppers drivers so that they won't burn hot smiley
Because I wanted to aim one of my fans towards the RAMPS board this is option will work just perfect for me smiling smiley
April 29, 2014 05:51PM
You'll be fountain of knowledge by the time you've finished! smileys with beer
Waitaki 3D Printer
