How to modify the Marlin Firmware for ceramic 3D printer!
Posted by yasin kilinc
May 06, 2014 02:59PM
Hi Everybody;
I use the RAMPS 1.4, the Marlin Firmware and the Pronterface for my ceramic 3d printer. I don't need any thermistor, so i have tried my ceramic 3d printer without thermistor. Every axis worked but Extruder didn't work. I tried, to modify configration.h but i couldn't solve the problem. Everything was fine on the Pronterface. When i click on extrude 5mm in pronterface it thinks its extruding but isn't. How can i solve this problem?
Edited 2 time(s). Last edit at 05/06/2014 03:09PM by yasin kilinc.
Re: How to modify the Marlin Firmware for ceramic 3D printer!
May 06, 2014 07:05PM
Look for the following in your Configuration.h in your Marlin firmware:
#define PREVENT_DANGEROUS_EXTRUDE
Just comment that out (put two /'s at the start) like so:
//#define PREVENT_DANGEROUS_EXTRUDE
Save, upload to the board, and you should be sorted.
May 07, 2014 01:15PM
Thanks for your help, i comment out that line but it didn't work. I couldn't turn the stepping motor of extruder.
Do you have any idea?
