Ramps disconnects when power is applied June 19, 2014 12:14PM |
Re: Ramps disconnects when power is applied June 19, 2014 06:49PM |
Re: Ramps disconnects when power is applied June 21, 2014 10:53PM |
Re: Ramps disconnects when power is applied June 22, 2014 09:51AM |
Re: Ramps disconnects when power is applied June 23, 2014 12:59PM |
Re: Ramps disconnects when power is applied June 23, 2014 01:41PM |
Re: Ramps disconnects when power is applied June 26, 2014 08:49AM |
Re: Ramps disconnects when power is applied June 29, 2014 04:19PM |
Re: Ramps disconnects when power is applied July 18, 2014 06:31PM |
blabberjack
Still going after abut 20 hours of printing, seems stable so I guess it was the PSU all along.
I wish I could recommend people experiencing this problem troubleshoot the output from their PSU first, but honestly I don't know how you would do that. One thing to bear in mind though is that of all the electronic parts, the PSU is the cheapest to replace so maybe if you encounter an issue like this, it would be worthwhile swapping out the PSU if there is no obvious damage to the board (might also be a good idea for someone with the know-how to put a section in the ramps wiki suggesting components/ traces to test and what to look for if you suspect a fault with your board). Sorry I can't just go and do that myself, I just don't have that experience!
