I'm thinking of building a CNC hot wire foam cutter, looking around for options... none too good for what I see.
So I was thinking how difficult would it be to use a RepRap derived mechanics and electronics for this purpose? Or, ideally, if someone has already done it so wouldn't have to reinvent the wheel.
What I have in mind is to use a software like
FoamWorks to generate the G-Code and then feed the code to the RAMPS controller, though I'm not sure if the code would be compatible with it.
It would be mostly a matter of configuring the RAMPs to run the four steppers (and maybe even the hotwire), would this be feasible?
Suggestions are welcome!
