I can not solve the problem, help![]() August 10, 2014 05:05PM |
Re: I can not solve the problem, help![]() August 11, 2014 07:07AM |
#define INVERT_X_DIR true // for Mendel set to false, for Orca set to true #define INVERT_Y_DIR false // for Mendel set to true, for Orca set to false #define INVERT_Z_DIR true // for Mendel set to false, for Orca set to true #define INVERT_E0_DIR false // for direct drive extruder v9 set to true, for geared extruder set to false #define INVERT_E1_DIR false // for direct drive extruder v9 set to true, for geared extruder set to false #define INVERT_E2_DIR false // for direct drive extruder v9 set to true, for geared extruder set to falseYou inverted the Stepper directions, you need to set the values according to the mendel Settings. Are your Endstops placed correctly? Are your Steppers wired correctly?
#define X_HOME_DIR -1 #define Y_HOME_DIR -1 #define Z_HOME_DIR -1
this means for me that you get an error each time you try to cnnect to the printer, ord did you mean something else?Quote
rao2_it
and the software can not connect without any error
Re: I can not solve the problem, help![]() August 11, 2014 08:45AM |
Re: I can not solve the problem, help![]() August 11, 2014 01:38PM |
Re: I can not solve the problem, help![]() August 11, 2014 01:41PM |
