5V out from ramps / Arduino August 12, 2014 07:24AM |
Re: 5V out from ramps / Arduino August 13, 2014 10:25AM |
Re: 5V out from ramps / Arduino August 13, 2014 10:37AM |
Re: 5V out from ramps / Arduino August 13, 2014 01:00PM |
cdru
You can get +5v from the Vcc pin next to the reset button on the ramps board. Note that you're limited by how much current you can draw via that pin and the more you draw, the hotter the voltage regulator will run. If you're using an ATX power supply, you'd be better off using a 5v line from there. Or just get a 7805 voltage regulator and power it from a 12v line.
Thank you for the reply. I am looking for a 'clean' pro-like solution.Quote
jaguarking11
Another thing that may be just as cheap if your using 12v only psu would be to buy one of those pharmacy store usb car chargers. They are like 4-6usd and wire them to the psu's 12v out. I plan on doing that for my wireless USB bridge.
Re: 5V out from ramps / Arduino August 13, 2014 04:10PM |
There's not much for a schematic. Pin 1 is the input (in your case +12v). Pin 2 goes to ground. Pin 3 is the +5v output. The output plus a ground just need to go to your connector.Quote
Crux
Thank you for the reply. I searched on google. I liked your suggestion! How can I wire the 7805 voltage regulator? Could you explain the schematic for it?
Re: 5V out from ramps / Arduino August 13, 2014 05:24PM |
