Problem with endstops X and Y axis September 08, 2014 10:16AM |
Re: Problem with endstops X and Y axis September 08, 2014 02:49PM |
Re: Problem with endstops X and Y axis September 12, 2014 08:50AM |
Config.h
#ifndef CONFIGURATION_H
#define CONFIGURATION_H
#define MOTHERBOARD 33
#define THERMISTORHEATER 1
#define THERMISTORBED 1
float axis_steps_per_unit[] = {53.333, 53.333, 3200/1.25, 618};
#define ENDSTOPPULLUPS // Comment this out (using // at the start of the line) to disable the endstop pullup resistors
const bool ENDSTOPS_INVERTING = true; //set to true to invert the logic of the endstops
#define BAUDRATE 115200
#define SDSUPPORT
#include "thermistortables.h"
#define X_ENABLE_ON 0
#define Y_ENABLE_ON 0
#define Z_ENABLE_ON 0
#define E_ENABLE_ON 0
const bool DISABLE_X = true;
const bool DISABLE_Y = true;
const bool DISABLE_Z = true; //false; //true;
const bool DISABLE_E = false;
const bool INVERT_X_DIR = false;
const bool INVERT_Y_DIR = false;
const bool INVERT_Z_DIR = true;
const bool INVERT_E_DIR = true;
#define X_HOME_DIR -1
#define Y_HOME_DIR -1
#define Z_HOME_DIR -1
const bool min_software_endstops = false; //If true, axis won't move to coordinates less than zero.
const bool max_software_endstops = false; //If true, axis won't move to coordinates greater than the defined lengths below.
const int X_MAX_LENGTH = 200; //200; //
const int Y_MAX_LENGTH = 200; //200;
const int Z_MAX_LENGTH = 135;
const int NUM_AXIS = 4; // The axis order in all axis related arrays is X, Y, Z, E
float max_feedrate[] = {200000, 200000, 240, 500000};
float homing_feedrate[] = {1500,1500,120};
bool axis_relative_modes[] = {false, false, false, false};
#define RAMP_ACCELERATION
#ifdef RAMP_ACCELERATION
float max_start_speed_units_per_second[] = {25.0,25.0,0.2,10.0}; // //10 for mosaic?
long max_acceleration_units_per_sq_second[] = {1000,1000,50,10000}; // X, Y, Z and E max acceleration in mm/s^2 for printing moves or retracts //100 Z for mosaic
long max_travel_acceleration_units_per_sq_second[] = {500,500,50,500}; // X, Y, Z max acceleration in mm/s^2 for travel moves //100 Z for mosaic
#endif
char uuid[] = "00000000-0000-0000-0000-000000000000";
#ifdef PIDTEMP
#define PID_MAX 255 // limits current to nozzle
#define PID_INTEGRAL_DRIVE_MAX 220
#define PID_PGAIN 180 //100 is 1.0
#define PID_IGAIN 2 //100 is 1.0
#define PID_DGAIN 100 //100 is 1.0
#endif
#define HEATER_CHECK_INTERVAL 500
#define BED_CHECK_INTERVAL 5000
#define DISABLE_CHECK_DURING_ACC
#ifndef DISABLE_CHECK_DURING_ACC
#endif
#define DISABLE_CHECK_DURING_TRAVEL 1000
#define MINTEMP 5
#define MAXTEMP 245
#define HEATER_USES_THERMISTOR
#define BED_USES_THERMISTOR
#ifdef DEBUG
#endif
#endif
Re: Problem with endstops X and Y axis September 23, 2014 12:45PM |
Re: Problem with endstops X and Y axis September 24, 2014 03:52AM |
Re: Problem with endstops X and Y axis September 24, 2014 08:54AM |
