Hot end not heating up Ramps 1.4 October 07, 2014 10:27AM |
Re: Hot end not heating up Ramps 1.4 October 07, 2014 09:27PM |
Re: Hot end not heating up Ramps 1.4 October 09, 2014 06:27PM |
Re: Hot end not heating up Ramps 1.4 October 10, 2014 04:17AM |
Re: Hot end not heating up Ramps 1.4 October 10, 2014 07:02AM |
Re: Hot end not heating up Ramps 1.4 October 10, 2014 02:27PM |
D8 and D10 as labeled on the RAMPS are digital pins 8 and 10 on the MEGA 2560 controller.Quote
derletztename
I work with RAMPS 1.4 at a very experimental printer and use my own very easy firmware to control it. Which PIN is assigned to D10 and D8 of the RAMPS?
-1 indicates that it's not used/not configured. Are you sure you're looking at the correct configuration for a RAMPS-based controller?Quote
Marlin says "-1" which I don't understand.
Re: Hot end not heating up Ramps 1.4 October 10, 2014 09:04PM |
dougal1957
D8 is normally for the heated bed and D10 is for EXT0 Hotend, Worth checking?
Doug
Re: Hot end not heating up Ramps 1.4 October 11, 2014 10:59AM |
Re: Hot end not heating up Ramps 1.4 October 11, 2014 01:38PM |
Re: Hot end not heating up Ramps 1.4 October 11, 2014 05:29PM |
Re: Hot end not heating up Ramps 1.4 October 15, 2014 07:32AM |
Re: Hot end not heating up Ramps 1.4 October 15, 2014 11:43AM |
D8 gets it's power from the 2nd input connector next right below it. You say that your voltage source is 12V 5A which is the other power input that powers everything except D8 which is typically only the heated bed, the highest current drawing device by far. If you don't have anything plugged into the 2nd power input, you won't get anything on D8.Quote
DIPtheRipper
Hi, there, I've working on my RAMPS 1.4 and had the similar problem. The voltage across D10 is 12v and the hot end works properly, but the voltage across D8 is 7mv and the printbed is not heating.
So is there any problems on the board or in my Arduino programming?
My voltage source is 12V 5A.
Re: Hot end not heating up Ramps 1.4 October 23, 2014 02:09PM |
Re: Hot end not heating up Ramps 1.4 October 23, 2014 03:50PM |
Re: Hot end not heating up Ramps 1.4 October 23, 2014 05:10PM |
Re: Hot end not heating up Ramps 1.4 October 24, 2014 10:41AM |
d8,d9,d10 ports not enabling on ramps 1.4+repetier firmware0.91 December 30, 2014 04:08AM |
Re: d8,d9,d10 ports not enabling on ramps 1.4+repetier firmware0.91 January 20, 2015 08:47AM |
anujpri
ramps not enabling d8,d9,d10 ports from repetier firmware.there is no voltage at these three ports. after verifying my repetier firmware still not able to figure it out. also the MOSFET's are working properly. any help would be appreciated.
Re: Hot end not heating up Ramps 1.4 May 02, 2015 11:13PM |
Re: Hot end not heating up Ramps 1.4 June 11, 2015 02:53PM |
