Tutorial: Fix RampsFD v1 bugs to get a highperformance Arduino DUE - Reprap Controller October 25, 2014 06:19AM |
Re: Tutorial: Fix RampsFD v1 bugs to get a highperformance Arduino DUE - Reprap Controller November 22, 2014 07:33PM |
Re: Tutorial: Fix RampsFD v1 bugs to get a highperformance Arduino DUE - Reprap Controller January 10, 2015 03:27PM |
Re: Tutorial: Fix RampsFD v1 bugs to get a highperformance Arduino DUE - Reprap Controller February 02, 2015 03:43PM |
Re: Tutorial: Fix RampsFD v1 bugs to get a highperformance Arduino DUE - Reprap Controller February 02, 2015 04:08PM |
Re: Tutorial: Fix RampsFD v1 bugs to get a highperformance Arduino DUE - Reprap Controller February 03, 2015 01:02AM |
Re: Tutorial: Fix RampsFD v1 bugs to get a highperformance Arduino DUE - Reprap Controller May 11, 2015 03:12PM |
Re: Tutorial: Fix RampsFD v1 bugs to get a highperformance Arduino DUE - Reprap Controller August 06, 2015 02:34AM |
cocktailyogi
Hello,
this is my first post. I have been following Reprap-community for years and build already 3 printers. Now it is time to return something.
This is a tutorial to fix most of the problems on RAMPS-FD v1 (Geetech) for Arduino Due.
Re: Tutorial: Fix RampsFD v1 bugs to get a highperformance Arduino DUE - Reprap Controller August 06, 2015 06:52PM |
Re: Tutorial: Fix RampsFD v1 bugs to get a highperformance Arduino DUE - Reprap Controller August 07, 2015 02:15AM |
I attach your firmware so I try on my board work temp sensorsQuote
tadawson
I'm running a V1 with Marlin4Due, and it's without fault . . . layer fan, automatic electronics fan, delta geometry, LCD, etc. all there and working.
Talk about this you've seen but expensive to buy and install the single components and not easy disaldare the first and resolder on V2Quote
tadawson
Oh, and you can get blank V2 cards from OSHPark, but would need to build it yourself . . . I may get a couple for grins, but I'm not sure there are any issues making me want to
- Tim
Re: Tutorial: Fix RampsFD v1 bugs to get a highperformance Arduino DUE - Reprap Controller August 07, 2015 10:48AM |
Re: Tutorial: Fix RampsFD v1 bugs to get a highperformance Arduino DUE - Reprap Controller August 20, 2015 05:07PM |
Re: Tutorial: Fix RampsFD v1 bugs to get a highperformance Arduino DUE - Reprap Controller August 20, 2015 08:57PM |
Re: Tutorial: Fix RampsFD v1 bugs to get a highperformance Arduino DUE - Reprap Controller August 21, 2015 01:48AM |
Re: Tutorial: Fix RampsFD v1 bugs to get a highperformance Arduino DUE - Reprap Controller August 29, 2015 07:37PM |
Re: Tutorial: Fix RampsFD v1 bugs to get a highperformance Arduino DUE - Reprap Controller August 29, 2015 08:15PM |
Jetguy
Here is an alternate mod that is WAAAAAY less complex and solves a number of issues.
#1 nothing wrong with the original MOSFETS since they are driven with 12V gate drive- they are fully on and into best case RDS on resistance.
#2 Yes, inverted logic is annoying but not impossible to deal with. Simply ensure the RAMPS-FD board has onboard regulation for logic voltage supplies should the DUE board fail.
Anyway, it's a 2 part mod. The pull up resistors is stupidly easy This solves about 90% of the safety aspect
[groups.google.com]
The local voltage regulation to handle complete DUE failure or if the DUE board was unplugged while the RAMPS-FD remained powered- this ensures the MOSFETS are always default off state.
[groups.google.com]
In all the fix could be done for under $2 if you had the parts in hand. It's that simple.
Re: Tutorial: Fix RampsFD v1 bugs to get a highperformance Arduino DUE - Reprap Controller August 31, 2015 03:42AM |
Re: Tutorial: Fix RampsFD v1 bugs to get a highperformance Arduino DUE - Reprap Controller August 31, 2015 11:52PM |
Re: Tutorial: Fix RampsFD v1 bugs to get a highperformance Arduino DUE - Reprap Controller September 01, 2015 03:30AM |
Re: Tutorial: Fix RampsFD v1 bugs to get a highperformance Arduino DUE - Reprap Controller September 01, 2015 06:48AM |
Triffid Hunter's Calibration Guide | --> X <-- Drill for new Monitor | Most important Gcode. |
Re: Tutorial: Fix RampsFD v1 bugs to get a highperformance Arduino DUE - Reprap Controller September 01, 2015 07:20AM |
Wurstnase
The proximity sensor they sell, is that the infrared-sensor from your design, dc42?
Re: Tutorial: Fix RampsFD v1 bugs to get a highperformance Arduino DUE - Reprap Controller November 07, 2015 10:00AM |
Re: Tutorial: Fix RampsFD v1 bugs to get a highperformance Arduino DUE - Reprap Controller November 09, 2015 05:12AM |
hellorous
So did you give up on RampsFD?
Re: Tutorial: Fix RampsFD v1 bugs to get a highperformance Arduino DUE - Reprap Controller November 21, 2015 04:39PM |
Re: Tutorial: Fix RampsFD v1 bugs to get a highperformance Arduino DUE - Reprap Controller November 21, 2015 09:26PM |
Delta
Sorry .. I ask what is the difference between a RampsFD V1 by a RampsFD V2 ?
As, I can recognize it ?
Re: Tutorial: Fix RampsFD v1 bugs to get a highperformance Arduino DUE - Reprap Controller November 24, 2015 09:53AM |
Re: Tutorial: Fix RampsFD v1 bugs to get a highperformance Arduino DUE - Reprap Controller November 25, 2015 11:11AM |
j.fabianski
Hello.
I have a question on Ramps-FD.
It's many different descriptions on net on this control board.
I have Ramps-FD ver. 1 rev. A by Geeetech.com which will be run only on 12V power supply.
I would like to simply ask what I have found to confirm which is better (1 or 2 or some combination of it ) and it's enough due to safety reasons on Ramps FD+ Due:
1. Link one :
Resistor pull--------- groups.google.com/d/msg/wanhao-printer-3d/Ol3WnLaut8A/7ryLgMwsCAAJ
Power add for Ramps FD------- groups.google.com/d/msg/wanhao-printer-3d/Ol3WnLaut8A/u2GUXTQuCAAJ
2. Link two: The pull up and down------ kreature.org/projects/3d_printer/rostock_plus/ramps-fd/
There is a need of installing so many pull up's and down's or part of link 1 is enough?
After this modification, can I use firmware as Ramps FD ver2 without additional invert?
The above links seems to be similar in pull up and pull down modification, seems easier then description in first post, this will give same effect (for me looks as similar solution)?
Do you know where to find description of serial pins and servo's to attached the external steering and ex. Wifi?
I have tried on Geetech.com to download schematic, but pdf was with some error.
Thanks.
Re: Tutorial: Fix RampsFD v1 bugs to get a highperformance Arduino DUE - Reprap Controller November 25, 2015 04:41PM |
Re: Tutorial: Fix RampsFD v1 bugs to get a highperformance Arduino DUE - Reprap Controller November 26, 2015 12:58PM |
Re: Tutorial: Fix RampsFD v1 bugs to get a highperformance Arduino DUE - Reprap Controller November 26, 2015 01:21PM |
