Intermittent heated bed issue November 18, 2014 03:34PM |
Re: Intermittent heated bed issue November 19, 2014 02:20AM |
Re: Intermittent heated bed issue November 21, 2014 05:05AM |
Re: Intermittent heated bed issue December 12, 2014 12:19PM |
Re: Intermittent heated bed issue December 12, 2014 01:47PM |
omphe
To complete this thread, in the end I elected to replace the 11A polyfuse with a 14A polyfuse. This now not only has the heat bed functioning perfectly, but it also runs at a cool temperature.
I can only presume that my heat bed was drawing just over the 11A and overheating the fuse.
Thanks Cefiar for the input and assistance with this issue.
Re: Intermittent heated bed issue December 15, 2014 10:24AM |
"Just over" doesn't apply to polyfuses. Just an amp or two might eventually trip it, but probably not for quite a while especially if it got up to temperature and only needed to maintain it intermittently. My heated for instance bed draws 15 amps through the 11 amp rated polyfuse and it's never tripped, even with long prints running at 110 degrees, but I also have a fan blowing over the entire ramps board.Quote
omphe
