extruder switched off maxtemp triggered December 02, 2014 11:58PM |
Re: extruder switched off maxtemp triggered December 03, 2014 03:37PM |
Re: extruder switched off maxtemp triggered December 03, 2014 04:19PM |
cdru
Our thermistors are usually NTC, negative temperature coefficient. As them goes up, resistance goes down. Maxtemp would indicate very low resistance, possibly indicating a short. However with everything unplugged, that's less likely but it still could be a problem with the RAMPS board. Check the solder joints to make sure there isn't any stray solder bridges. Also double check that your config files are correct and using the right pins.
Re: extruder switched off maxtemp triggered December 03, 2014 04:24PM |
Re: extruder switched off maxtemp triggered December 03, 2014 04:39PM |
Re: extruder switched off maxtemp triggered December 04, 2014 11:34PM |
cdru
I can almost guarantee you that you don't have #8. 0603 SMD is a surface mount form factor size. The Ubis looks to have a glass bead. 1 and 6 are very popular, but honestly unless you know for sure many of them might be close, but might not. I found a reference that said the Ubis thermistor looked identical to an EPCOS, but it wasn't very authoritative and looks can be deceiving so I wouldn't rely on it. If you have a thermocouple you could generate your own table by measuring what temperature the hot end is and measuring the resistance. 3 points is all that's needed to generate the curve.
Are you getting any reading as to the temperature? It should be 18+/- degrees C depending on room temperature. If it reads zero (and you aren't in a freezer), then min temp was triggered because it's an open circuit. Just as very low resistance measures maxtemp, very high resistance (or infinite resistance aka open) measures as mintemp.
Re: extruder switched off maxtemp triggered December 05, 2014 03:22PM |
Adjust pots on drivers, presuming that they turn by hand without significant resistance or binding when not powered.Quote
Now to deal with other issues, some motors are moving and others are just making noise. I am sure it is another configuration. I will look into that later before opening another thread.
