RAMPS 1.4 fuse overheats within seconds. Do I have a bad fuse? December 28, 2014 03:38PM |
Has anyone ever had a similar problem? Should I replace my RAMPS 1.4 board (admittedly, it was the cheapest one I could find on eBay)?
Re: RAMPS 1.4 fuse overheats within seconds. Do I have a bad fuse? December 28, 2014 05:02PM |
Re: RAMPS 1.4 fuse overheats within seconds. Do I have a bad fuse? December 29, 2014 06:21AM |
Re: RAMPS 1.4 fuse overheats within seconds. Do I have a bad fuse? January 02, 2015 02:27PM |
Re: RAMPS 1.4 fuse overheats within seconds. Do I have a bad fuse? January 05, 2015 12:20PM |
PID or bang bang shouldn't make a difference which initially turning it on. The difference would only come into play once the temperature comes near the target.Quote
maddane
Just curious are you set up for PID or bang bang on the heat bed. I tried PID and my board acted the same way. Bang bang works fine.
Re: RAMPS 1.4 fuse overheats within seconds. Do I have a bad fuse? March 19, 2015 03:04PM |
Re: RAMPS 1.4 fuse overheats within seconds. Do I have a bad fuse? March 20, 2015 09:51AM |
Re: RAMPS 1.4 fuse overheats within seconds. Do I have a bad fuse? March 20, 2015 05:49PM |
Re: RAMPS 1.4 fuse overheats within seconds. Do I have a bad fuse? March 23, 2015 09:21AM |
Re: RAMPS 1.4 fuse overheats within seconds. Do I have a bad fuse? March 27, 2015 06:45AM |
Re: RAMPS 1.4 fuse overheats within seconds. Do I have a bad fuse? March 27, 2015 09:05AM |
Whatever you wish. Functionally, they will all do the same. You can get an inline fuse for your supply line, a solder in socket that mounts on the board, or a socket on leads that get soldered and the fuse kinda dangles.Quote
Nachbar
Now i am looking for nice holders like on the RAMPS 1.4.2
Or i will just connect some cables or something like that.
