SD card listing January 04, 2015 08:00AM |
Re: SD card listing January 04, 2015 10:09AM |
Admin Registered: 17 years ago Posts: 7,879 |
Re: SD card listing January 04, 2015 10:12AM |
Re: SD card listing January 04, 2015 10:32AM |
Re: SD card listing January 04, 2015 07:28PM |
UkIan
DC, I've given up on the Duet for the moment. I cannot get the firmware to build at all. Each time I've tried I get a different set of issues. My biggest concern is I do get it to build, rely on it, something changes and I'm no longer able to build. I'll pop a more detailed post over in the other sub-forum.
Re: SD card listing January 05, 2015 09:00AM |
dc42
UkIan
Do you really need to build it? You only need to build it if you want to change its functionality (unlike Marlin. which you need to rebuild every time you change the configuration parameters).
There is a guide to setting up the build system here [blog.think3dprint3d.com]. One thing that I discovered is that Eclipse does not take kindly to space characters in its workspace path. Also note that some of the code in the official RRP release will not compile if you use the latest version of the Arduino IDE, so stick to the recommended (old) version.
Re: SD card listing January 05, 2015 04:43PM |
Re: SD card listing January 05, 2015 04:57PM |
Re: SD card listing January 05, 2015 06:01PM |
E:\A\arduino157\hardware\tools> bossac --port=com7 -U true -e -w -v -b -R e:\RepRapFirmware-065k-dc42.bin
Re: SD card listing January 06, 2015 08:16AM |
Re: SD card listing January 06, 2015 03:29PM |
Re: SD card listing January 06, 2015 05:52PM |
Re: SD card listing January 07, 2015 04:40AM |
