Marlin and LCD issue ( FULL_GRAPHIC_SMART_CONTROLLER) January 20, 2015 09:09AM |
Re: Marlin and LCD issue ( FULL_GRAPHIC_SMART_CONTROLLER) January 20, 2015 10:25AM |
Re: Marlin and LCD issue ( FULL_GRAPHIC_SMART_CONTROLLER) January 21, 2015 06:15AM |
........................................ //LCD and SD support //#define ULTRA_LCD //general LCD support, also 16x2 //#define DOGLCD // Support for SPI LCD 128x64 (Controller ST7565R graphic Display Family) #define SDSUPPORT // Enable SD Card Support in Hardware Console //#define SDSLOW // Use slower SD transfer mode (not normally needed - uncomment if you're getting volume init error) //#define SD_CHECK_AND_RETRY // Use CRC checks and retries on the SD communication //#define ENCODER_PULSES_PER_STEP 1 // Increase if you have a high resolution encoder //#define ENCODER_STEPS_PER_MENU_ITEM 5 // Set according to ENCODER_PULSES_PER_STEP or your liking //#define ULTIMAKERCONTROLLER //as available from the Ultimaker online store. //#define ULTIPANEL //the UltiPanel as on Thingiverse //#define LCD_FEEDBACK_FREQUENCY_HZ 1000 // this is the tone frequency the buzzer plays when on UI feedback. ie Screen Click //#define LCD_FEEDBACK_FREQUENCY_DURATION_MS 100 // the duration the buzzer plays the UI feedback sound. ie Screen Click // The MaKr3d Makr-Panel with graphic controller and SD support // [reprap.org] //#define MAKRPANEL // The RepRapDiscount Smart Controller (white PC // [reprap.org] //#define REPRAP_DISCOUNT_SMART_CONTROLLER // The GADGETS3D G3D LCD/SD Controller (blue PC // [reprap.org] //#define G3D_PANEL // The RepRapDiscount FULL GRAPHIC Smart Controller (quadratic white PC // [reprap.org] // // ==> REMEMBER TO INSTALL U8glib to your ARDUINO library folder: [code.google.com] #define REPRAP_DISCOUNT_FULL_GRAPHIC_SMART_CONTROLLER // The RepRapWorld REPRAPWORLD_KEYPAD v1.1 // [reprapworld.com] //#define REPRAPWORLD_KEYPAD //#define REPRAPWORLD_KEYPAD_MOVE_STEP 10.0 // how much should be moved when a key is pressed, eg 10.0 means 10mm per click // The Elefu RA Board Control Panel // [www.elefu.com] // REMEMBER TO INSTALL LiquidCrystal_I2C.h in your ARUDINO library folder: [github.com] //#define RA_CONTROL_PANEL //automatic expansion #if defined (MAKRPANEL) #define DOGLCD #define SDSUPPORT #define ULTIPANEL #define NEWPANEL #define DEFAULT_LCD_CONTRAST 17 #endif #if defined (REPRAP_DISCOUNT_FULL_GRAPHIC_SMART_CONTROLLER) #define DOGLCD #define U8GLIB_ST7920 #define REPRAP_DISCOUNT_SMART_CONTROLLER #endif #if defined(ULTIMAKERCONTROLLER) || defined(REPRAP_DISCOUNT_SMART_CONTROLLER) || defined(G3D_PANEL) #define ULTIPANEL #define NEWPANEL #ifndef ENCODER_PULSES_PER_STEP #define ENCODER_PULSES_PER_STEP 1 #endif #ifndef ENCODER_STEPS_PER_MENU_ITEM #define ENCODER_STEPS_PER_MENU_ITEM 5 #endif #endif ...................................................
.............................. #ifdef NEWPANEL #define LCD_PINS_RS 16 #define LCD_PINS_ENABLE 17 #define LCD_PINS_D4 23 #define LCD_PINS_D5 25 #define LCD_PINS_D6 27 #define LCD_PINS_D7 29 #ifdef REPRAP_DISCOUNT_SMART_CONTROLLER #define BEEPER -1 //#define BEEPER 37 //TVJ #define BTN_EN1 31 //31 #define BTN_EN2 33 //33 #define BTN_ENC 35 #define SDCARDDETECT 49 ....................
Re: Marlin and LCD issue ( FULL_GRAPHIC_SMART_CONTROLLER) January 21, 2015 06:24AM |
..................................... SERIAL_ECHO_START; SERIAL_ECHOPAIR("enc=",(unsigned long)enc); SERIAL_ECHOLN(""); switch(enc) { case encrot0: if(lastEncoderBits==encrot3) encoderDiff++; else if(lastEncoderBits==encrot1) encoderDiff--; break; case encrot1: if(lastEncoderBits==encrot0) encoderDiff++; else if(lastEncoderBits==encrot2) encoderDiff--; break; case encrot2: if(lastEncoderBits==encrot1) encoderDiff++; else if(lastEncoderBits==encrot3) encoderDiff--; break; case encrot3: if(lastEncoderBits==encrot2) encoderDiff++; else if(lastEncoderBits==encrot0) encoderDiff--; break; } } lastEncoderBits = enc; } ................................................
Re: Marlin and LCD issue ( FULL_GRAPHIC_SMART_CONTROLLER) January 22, 2015 11:40AM |
Re: Marlin and LCD issue ( FULL_GRAPHIC_SMART_CONTROLLER) January 24, 2015 04:39PM |
Re: Marlin and LCD issue ( FULL_GRAPHIC_SMART_CONTROLLER) July 20, 2016 09:25AM |
Connecting... start Printer is now online. echo:Marlin 1.1.0-RC6 echo: Last Updated: 2016-04-24 12:00 | Author: (none, default config) Compiled: Jul 20 2016 echo: Free Memory: 11390 PlannerBufferBytes: 1168 echo:Hardcoded Default Settings Loaded echo: Steps per unit: echo: M92 X80.00 Y80.00 Z4000.00 E500.00 echo:Maximum feedrates (mm/s): echo: M203 X300.00 Y300.00 Z5.00 E25.00 echo:Maximum Acceleration (mm/s2): echo: M201 X3000 Y3000 Z100 E10000 echo:Accelerations: P=printing, R=retract and T=travel echo: M204 P3000.00 R3000.00 T3000.00 echo:Advanced variables: S=Min feedrate (mm/s), T=Min travel feedrate (mm/s), B=minimum segment time (ms), X=maximum XY jerk (mm/s), Z=maximum Z jerk (mm/s), E=maximum E jerk (mm/s) echo: M205 S0.00 T0.00 B20000 X20.00 Z0.40 E5.00 echo:Home offset (mm): echo: M206 X0.00 Y0.00 Z0.00 echo:Material heatup parameters: echo: M145 S0 H180 B70 F0 echo: M145 S1 H240 B110 F0 echo: PID settings: echo: M301 P22.20 I1.08 D114.00 C100.00 L20 echo:Filament settings: Disabled echo: M200 D3.00 echo: M200 D0 echo:enc=2 echo: SD card ok
Re: Marlin and LCD issue ( FULL_GRAPHIC_SMART_CONTROLLER) July 20, 2016 09:44PM |
ArielRi
I have the same problem, when I put your debug line my board show this:
the "enc=2" appear whitout touching anything.
Do you know how can I detect the issue?
Tkz in advance.
