RAMPS 1.4 SB with quality components January 21, 2015 11:39AM |
Re: RAMPS 1.4 SB with quality components January 21, 2015 02:46PM |
The original ramps called for a 15 amp connector. It's just the cheapskate manufacturers try to use cheaper components. Even at 15amps though you're right at the line and it doesn't allow for much wiggle room if you have a poor connection, oxidation, etc. I'd like to see one that is significantly higher than 15 amps which is what my board draws. Plus, you're still using a 11amp polyfuse.Quote
staticboards
The power connectors are original molex rated at 15A.
What toshiba mosfet are you using?Quote
The MOSFETs are toshiba, rated at 70A of constant usage, with a very low resistance. They keep a low temperate during hours of printing.
Shouldn't be necessary. All circuits have inductance, but with resistance heaters it's essentially zero. Fans would be the only thing the typical printer would have connected and the small inductive load is easily handled by the body diode inside most MOSFET packages (including the usual MOSFETs used with a RAMPS board)Quote
The protection diodes will protect the electronic from the stored inductance on the heat bed and extruder.
Re: RAMPS 1.4 SB with quality components January 22, 2015 08:50AM |
Re: RAMPS 1.4 SB with quality components January 22, 2015 11:20AM |
IRLB8743PbF often is recommended as a better replacement for "standard" RAMPS boards. It looks like it has a 1/3 lower typical Rds(on) and a lower junction-to-ambient thermal resistance so if my numbers are correct, the IRLB8743PbF should run about 1/2 as hot over ambient temp at the load typical for a heated bed. It's also is available, at least here in the US, at less than 1/2 the cost in reasonable quantities. Either though are light years better than stock.Quote
staticboards
The exact model for the mosfet is the TK72E12N1,S1X , not cheap, but I really love the low resistance.
Re: RAMPS 1.4 SB with quality components February 11, 2015 05:55PM |
Re: RAMPS 1.4 SB with quality components March 25, 2015 11:59AM |
Re: RAMPS 1.4 SB with quality components March 25, 2015 11:04PM |
Admin Registered: 15 years ago Posts: 7,320 |
