Is it possible to use RAMPS to output 5V to load a Raspberry Pi (Octoprint)? January 26, 2015 11:45AM |
Re: Is it possible to use RAMPS to output 5V to load a Raspberry Pi (Octoprint)? January 26, 2015 01:12PM |
Re: Is it possible to use RAMPS to output 5V to load a Raspberry Pi (Octoprint)? January 26, 2015 05:43PM |
Re: Is it possible to use RAMPS to output 5V to load a Raspberry Pi (Octoprint)? January 27, 2015 03:14AM |
Re: Is it possible to use RAMPS to output 5V to load a Raspberry Pi (Octoprint)? January 27, 2015 10:01AM |
Re: Is it possible to use RAMPS to output 5V to load a Raspberry Pi (Octoprint)? January 27, 2015 07:24PM |
Re: Is it possible to use RAMPS to output 5V to load a Raspberry Pi (Octoprint)? January 28, 2015 09:58AM |
Any power supply that falls within the designed input voltage. Most power supplies I've seen are rated at some value over 24V, but there are so many slightly different ones that you have to double check if you're running higher voltags. But any should work for 12V -> 5V.Quote
dolphinboy
I like the idea of the LM2596... is it possible to attach it to any power supply? is there any tutorial on how to use it?
Re: Is it possible to use RAMPS to output 5V to load a Raspberry Pi (Octoprint)? February 03, 2015 08:12AM |
