RAMPS1.4 - Heatbed wont heat up to 100C
Posted by skelator
February 10, 2015 10:03PM
I'm trying to figure out what when wrong here, I bought a aluminum heated bed from a local vendor here in my country but I can't seem to get it to heat up to 110c it just hover at 88c, some people suggested to change the mosfet which I did change it with this one
IRLB8743PBF [my.element14.com]
but it does not fix the problem, my setup currently using 12v 30A Led power supply and while heating I can confirm that the mosfet did not overheat it just stay around 35C-40C, the polyfuse are at normal tempeture too, would it safe to assume that the alunimum heatbed is the culprit here? I bought 2 of them the second one on my prusa i3 only manage to get to 98C max it can't go any higher than that, firmware already set to 255 the pid max setting
FYI I get 1.8ohm when I measured the resistant of the copper trace while my old mk2a pcb heated bed is 1.2ohm
Edited 1 time(s). Last edit at 02/10/2015 10:03PM by skelator.
Re: RAMPS1.4 - Heatbed wont heat up to 100C
February 11, 2015 04:12AM
1. Measure the voltage appearing on the heat bed. If it is much lower than the 12V from your power supply, then you are losing too much in the cabling and/or the mosfet.
2. You didn't say what size the heated bed is. If it is about 200mm square then a resistance of 1.8 ohms is rather high and you will need more voltage to get it hotter.
3. As you have a LED supply, you can turn up the supply voltage. Caution: if you are using Arduino/RAMPS and you have an LCD screen attached with the backlight powered from 5V, then the voltage regulator on the Arduino will already be getting very hot, and you should use an external 5V regulator before you increase the voltage. Otherwise, you can turn the voltage up to 14V.
4. Insulation under the bed will help.
February 11, 2015 04:37AM
dc42
Will do that when I get home but my heat bed is wired with 16AWG silicon wire normally used for RC
dc42
my heated bed are 200x200 standard size
dc42
noted I will need to look up on on how to do this, maybe I can just disable the backlight
dc42
my alunimum bed is mounted on a MDF plate
Edited 1 time(s). Last edit at 02/11/2015 04:38AM by skelator.
February 11, 2015 05:07AM
skelator
dc42
The funny thing is, some people scream that you shouldn't feed more than 12V to the Arduino Mega (which is rated at 20V maximum) for fear of overheating the regulator; but they are quite happy to power a 12864 graphic LCD from the 5V rail - which causes the regulator to get hotter than is wise even with 12V input.
I would disconnect the backlight anode from the 5V supply and connect it through a series resistor to +12V (which is about to become +14V). If it is a 12864 mono graphics LCD, then the backlight needs about 100mA, so a 100 ohm 2W resistor would be about right. Depending on how good the PSU regulation is, you may see the backlight dim slightly when the heated bed is on.
The LED supply will have a voltage adjustment pot near one end of the terminal block.
Edited 1 time(s). Last edit at 02/11/2015 05:14AM by dc42.
February 11, 2015 06:39AM
If you want to eliminate the controller from your suspect list, just wire the heatbed directly to your 12V power supply for testing. If it can't reach 110C wired directly to the power supply, you know what the problem is.....
February 11, 2015 06:52AM
vreihen
An excellent suggestion. You can also turn up the voltage to 14V with just the heat bed connected to the PSU, to see if additional voltage fixes the problem, before you make any changes to the printer electronics to accommodate 14V input.
February 11, 2015 07:31AM
ok did some check
power getting to the heatbed is 11.5v power measured directly from the power supply are 11.85v not actually 12v or maybe it my multimeter smiling smiley but my Watt Meter does said it 11.85v so I guess my multimeter is correct, If I turn up my power to 14v I need to find a resistor to drop my voltage to 12v as I have a fans running directly from the 12v source not sure the can can handle 12v smiling smiley and will my stepper motor run fine with 14v? I dont see any label on the stepper motor indicating working voltage
February 11, 2015 07:38AM
The stepper motor drivers are constant-current and can take much higher voltages than 12V (AFAIR they are rated at 35V). The capacitors on the RAMPS board may be rated at 16V, 25V or possibly 35V depending on your board. A simple way to drop the voltage to the fans from 14V to 12V is to put three 1N4001 or similar diodes in series with them.
February 11, 2015 07:46AM
dc42
ok noted I put some diode for the fans or maybe hookup and one of my stepdown regulator for fans and LED
UPDATE:
Bumped the power supply to 14v, finally barely heated up to 105c, if my calculation are correct with 14v and 1.8ohm resistance on the board, it need 25A just to heat the bed up!
I did also wired the heated bed directly to the power supply and adjusting the voltage while at it with 13.95v it can go up to 105 and stuck there unless I bump the voltage even more
Edited 1 time(s). Last edit at 02/11/2015 09:08AM by skelator.
February 11, 2015 05:07PM
Ohm's law: U(volts) = I(amps) x R(ohm). ==> I = U/R ==> I = 14/1,8 ==> I = 7,77 Amp.
Have measured the actual temperature, maybe your thermistor is misreading.
February 11, 2015 08:37PM
gforce1
the thermistor is acurate, only -/+ 5 degrees as I also measured with my IR thermometer just incase, but 1 thing for sure with 12v the bed will never ever heat up to 100c that for sure
February 12, 2015 04:31AM
You could bump the supply voltage to 15V if the PSU will go that high and has enough spare current capacity, but if the capacitors on your RAMPS board are only rated at 16V that leaves very little margin unless you replace them with 25V capacitors. Otherwise, I suggest you look for a different heat bed.
February 12, 2015 05:34AM
Just to check before you replace any more hardware, you did check that PID is correctly tuned, didn't you?
If the heatbed has an LED it is easy to check, the LED shouldn't flicker before you get close to your target temperature. If it flickers that is PID switching the current on and off, when it hasn't been tuned PID can cut in way too soon, meaning you are not getting full current to the bed when you need it.
EDIT
Just noticed you already tried hooking directly to the PSU, so that eliminates PID from the equation.
Edited 1 time(s). Last edit at 02/12/2015 05:45AM by plankton.
February 15, 2015 09:23PM
Ok,
did my first print on ABS I keep my voltage to 14v as dc42 suggested, can't go to 15v as check the capasitor it only rated to 16v I don't want to risk it, bed will take a while to reach 100c but it can..
now having problem with my marlin, I already enabled BED Pid in firmware configuration but M304 wont give me anything, so can't really set the PID for the bed need to figure out why. Plus I need a new ABS spool the one I have already exposed to moisture quite long time getting popping sound while printing, maybe I'm going to bake the filament to dry it out when My wife is not around :p
February 16, 2015 03:29AM
You don't need to use PID control for the bed, and using it may make the mosfet run hotter. Leave it as bang-bang instead.
[SOLVED] RAMPS1.4 - Heatbed wont heat up to 100C
February 16, 2015 03:33AM
dc42
ok I'll leave the bed as default for now, reason enabling was I'm expecting a Solid State relay to arrive anytime soon now smiling smiley, but first thing first I need to dry my filament smiling smiley
Edited 1 time(s). Last edit at 02/16/2015 03:34AM by skelator.
Re: [SOLVED] RAMPS1.4 - Heatbed wont heat up to 100C
February 16, 2015 06:11AM
Using a SSR with that heat bed will probably reduce its output, because an SSR will have a higher voltage drop than the mosfet on the RAMPS board.
February 16, 2015 07:01AM
skelator
...but first thing first I need to dry my filament smiling smiley
Instead of waiting for the absence of adult supervision, put your heatbed to work while you're testing it. Put the spool in the center of your heatbed, and cover it with a small cardboard box. I do not know how it will work, but plan to try it myself sooner or later because my kitchen autoclave^H^H^Hoven smiling smiley is only 6 months old and cost me over $1,200.....
July 29, 2015 01:50PM
just wondering, I have no fan on the ramp board, only fan thats working is in the psu, other than that, none, I did have a fan on D9 but now D9 has no current, both the heatbed and extruder are getting less than 12v when heating, anything I need to look out for when cranking up the voltage?
thanks
July 29, 2015 02:16PM
D9 should not be powered until an M106 commands it on, and is used for a layer fan, not the hot end fan, which should be wired to 12v directly. What voltages are you seeing? Supply out, board in, and heatbed out? Check also that you are not using too small a wire to the heatbed/board . . . 16ga would concern me, 14 may be OK, myself I'd use 12ga or 10ga to minimize losses.
- Tim
Edited 3 time(s). Last edit at 07/29/2015 02:20PM by tadawson.
July 29, 2015 02:37PM
supply to board is only 12.06v when nothing is on, once heatbed is on, supply in drop to 11.6v output to bed only 11.49v I cracnked up the voltage on PSU to 12.6v, now with extruder and bed both switched on they are both getting 12.03v, you are correct on the fan, but my problem there is m106 does nothing, the output is dead, it was working, but just went dead all of a sudden, I have 35v caps on this board, and I bought a new one in the post, but just checked the new one I order, has only 16v caps sad smiley not sure the wire ga, I use household electrical wires, the one came with it was 16ga, I swapped that out few weeks ago and gave me more temp, 16ga I was struggling to get 95c nevermind 100c or above, after switching out the wires, I got just 100c but I need another 10c to 20c more, even at 11c and able to keep up 100c while printing would be a big improvement
just testing the bed now, at 94c at the miniute, but only took few minutes to get that instead of 30mins and moving up slowly from here on
its stalling at 99.1c struggling, thats almost 10c improved
cranked it up another bit, still below 13v from psu to board in, heating faster now, dropped to 86c when I turned it off to up the voltage, and its back to 93c in seconds
would you think it be safe to crank it to 12.95v without step down, I'm not familiar with these electronics, I only go by what I know with cars...
Edited 4 time(s). Last edit at 07/29/2015 03:25PM by deaconfrost.
July 29, 2015 06:55PM
At this point, if you have not already done so, insulating the bottom of the bed may do the trick. I couldn't getbover 95 on my Kossel, but with about 1/2" of foam under the bed, I hit 100 withot any trouble.
And you have not changed any firmware or anything along those lines? Perhaps a MOSFET has failed . . . there really isn't much on the RAMPS between the Arduino and the FET.
Oh, and only dropping .1v supply to the bed isn't enough that I would worry myself . . . looks like the power supply regulation is a bit soft, though . .
- Tim
July 29, 2015 07:49PM
yep I have reprap sheet under the bed and printer is in a chamber
I have the voltage at 12.94v to the board, bed and extruder now keeping above 12v and bed holding 105c during print
Edited 1 time(s). Last edit at 07/29/2015 07:50PM by deaconfrost.
August 10, 2015 12:01PM
a bit of update on bed temp in regards to curling, I just printed out this 20mm cube at 84c starting bed temp, how did that managed? it wasn't completely glued to the bed when print was finished but it did have some hold on the bed..... but that's after everything I've done to the print in this post [forums.reprap.org]
straight to glass no tape no abs juice nothing. not a very clean print, was just doing it at rather a bit high speed just to see if I got the offset and servo angle right
not sure if its the thermistor at faults, but last time I waited the bed to hit 105c, then start print, and the first layer was curling like there's no tomorrow
Edited 2 time(s). Last edit at 08/10/2015 12:24PM by deaconfrost.
August 13, 2015 02:51AM
At those high printbed temps an open window or a person passing by have a lot more effect on the print. That's why the ABS printers should be enclosed. ( That and the cancerous fumes from ABS sad smiley )
-Olaf
May 19, 2016 02:51AM
Hi, sorry to ask, as i'm not a electrician so i not sure, the step to change the voltage of the motherboard to 12.95V, can you write in detail on the step so everyone can use it ? would be grateful for you to do this! smiling smiley thanks you and appreciate your notes!
November 30, 2022 09:10AM
Hi. I know this thread is old.
But I just registered to say THANK YOU
for all of the discussion. Every step. I managed to sort my problem. Just a bit of context: Mine couldn't heat past 82C.
So I measured the heat bed terminals while it was heating up. It was showing 10.45V and the input voltage was 12.02V.
So I recrimped the connectors and put solder on the end lugs and plugged them into RAMPS. Then I got better bed voltage. I also upped the voltage from the PSU to 13.3V which made it 13V when the printer is turned on. The voltage at the bed when heated is now 12.75V.
@evetanlm I unscrewed the power supply housing, opened the lid and carefully turned the potentiometer inside with a screw driver. Have to be very careful because this its dangerous (240V source) and there's lots of capacitors if you slip
