5V relay activation? February 18, 2015 11:30PM |
Re: 5V relay activation? February 19, 2015 08:38AM |
Re: 5V relay activation? February 19, 2015 12:49PM |
Re: 5V relay activation? February 19, 2015 02:50PM |
MindRealm
I have been running a dual-relay module on my printer for months without problems...
Thingiverse
Re: 5V relay activation? February 19, 2015 04:38PM |
Re: 5V relay activation? February 19, 2015 06:55PM |
MindRealm
From what I understand, the Arduino Mega 2560 max current on the 5v regulator is 500mA.
Re: 5V relay activation? February 19, 2015 07:38PM |
Admin Registered: 15 years ago Posts: 7,341 |
Re: 5V relay activation? February 19, 2015 07:55PM |
Dust
There doesnt seem to be any link to that relay module, but there are chips on it.. I suspect its opticaly isolated or otherwise protected.
Ie coils are not directly on the IO pin.
Re: 5V relay activation? February 20, 2015 01:44AM |
Re: 5V relay activation? February 20, 2015 10:50AM |
The spec sheet for the Songle 5V relay that is most often found on those boards says that the relay coil has a nominal current draw of 89.3 mA which, at 5 volts, comes out to about .45 watts (which is also stated). Now what they state and what it actually draws can be two different things. But your module may not be the same as someone else's module either.Quote
MindRealm
The relay module shouldn't draw more than 40-50mA, plus a small amount for the LED on the module.
Re: 5V relay activation? February 20, 2015 04:23PM |
Re: 5V relay activation? February 20, 2015 04:57PM |
kd6hq
Thank you everyone.
All in all it sounds like it is more trouble than it's worth.
Right now I just turn everything on with a switch. Just means that some
of the fans and lights run all the time, no big deal I just figured if it was
possible why not!
thanks again
Re: 5V relay activation? February 20, 2015 07:33PM |
