Re: How to modify a standard RAMPS 1.4 to work with Arduino Due? April 17, 2015 08:06PM |
AndrewBCN
The really critical MOSFET is without any doubt the heatbed one, in my case I have replaced the one that came on my RAMPS clone with a IRLB8743 (as discussed above), which apparently can handle the 10A or so required by the heatbed even when driven by the 3.3V ARM MCU.
Re: How to modify a standard RAMPS 1.4 to work with Arduino Due? April 17, 2015 09:49PM |
Re: How to modify a standard RAMPS 1.4 to work with Arduino Due? April 17, 2015 10:45PM |
Re: How to modify a standard RAMPS 1.4 to work with Arduino Due? April 18, 2015 01:53AM |
Re: How to modify a standard RAMPS 1.4 to work with Arduino Due? April 18, 2015 05:19AM |
Re: How to modify a standard RAMPS 1.4 to work with Arduino Due? April 18, 2015 09:04AM |
Admin Registered: 19 years ago Posts: 7,883 |
Re: How to modify a standard RAMPS 1.4 to work with Arduino Due? April 18, 2015 09:12AM |
nophead
I can't see anything in the datasheet to guarentee that. It only quotes Rds(on) at 4.5V and 10V and I can't see a graph of it against Vgs.
Re: How to modify a standard RAMPS 1.4 to work with Arduino Due? April 18, 2015 09:24AM |
Re: How to modify a standard RAMPS 1.4 to work with Arduino Due? April 18, 2015 09:32AM |
Re: How to modify a standard RAMPS 1.4 to work with Arduino Due? April 18, 2015 09:39AM |
dc42
nophead
I agree. Again, the graph of typical characteristics suggests that you will typically get away with 3.3V gate drive, but it isn't guaranteed.
Re: How to modify a standard RAMPS 1.4 to work with Arduino Due? April 18, 2015 09:40AM |
Re: How to modify a standard RAMPS 1.4 to work with Arduino Due? April 18, 2015 10:17AM |
Re: How to modify a standard RAMPS 1.4 to work with Arduino Due? April 18, 2015 11:43AM |
AndrewBCN
What's the problem here, a case of collective blindness?
You have the curves for VGS=3V on page 3, for T=25 and T=175, in both cases the IRLB3034 can easily switch something like 60A. Even if you derate that for a worst-case MOSFET sample, we should still be well within safe margins with our 10A heatbed.
Re: How to modify a standard RAMPS 1.4 to work with Arduino Due? April 18, 2015 12:58PM |
nophead
The graphs show it will pass the current but don't show Rds, so its hard to say how hot it will get without a heatsink.
nophead
One can say at 30A it would drop about 0.1V but it would then dissipate 3W, which is too much for TO220 with no heatsink. And they are just typical values. When designing volume electronics you have to use worst case or else you end up without a leg to stand on when you get a big batch or parts that are within spec but not typical.
Re: How to modify a standard RAMPS 1.4 to work with Arduino Due? April 18, 2015 02:50PM |
bigfilsing
Or you use a 5 dollar solid state relay and put all the mosfet woes behind you ( well most of them) and gain access to using 24 volt for your heated bed.
Even in its standard state with Mega & ramps1.4 taking the 10amp current and potential autofuse/ mosfet issues away from the ramps has to be a good thing right?
Re: How to modify a standard RAMPS 1.4 to work with Arduino Due? April 18, 2015 03:00PM |
AndrewBCN
Indeed hard to say, so why not try a few IRLB3034's and then find out whether it overheats or not? Oh, wait, that's exactly what enif did!
AndrewBCN
We just need it to switch approx. 10A. If we interpret the curves from the datasheet and derate Rds accordingly when going from Vgs = 4.5V to Vgs = 3.0V we still end up way below 0.003 Ohm i.e. way below 300mW.
Re: How to modify a standard RAMPS 1.4 to work with Arduino Due? April 18, 2015 03:02PM |
Re: How to modify a standard RAMPS 1.4 to work with Arduino Due? April 18, 2015 03:34PM |
Re: How to modify a standard RAMPS 1.4 to work with Arduino Due? April 18, 2015 10:54PM |
Re: How to modify a standard RAMPS 1.4 to work with Arduino Due? April 19, 2015 04:29AM |
bigfilsing
Please forgive my limited knowledge of electronic components and principles but id like to understand this more.
I understand that due to the fabrication process the gate threshold maybe as high as 2.5V . I understand that due to voltage regulators /PCD traces etc the gate drive maybe as low as 3V .
The bit i dont get is how that could potentially equate to a 15V drop.??
Thanks
Re: How to modify a standard RAMPS 1.4 to work with Arduino Due? April 19, 2015 05:40AM |
Re: How to modify a standard RAMPS 1.4 to work with Arduino Due? April 19, 2015 05:49AM |
bigfilsing
Thanks DC42
One last question then ill stop ...promise
Is there any significance to them in fig 1 ( and other figs) zooming the graph at 1 to 2 volts and 10 to 20 volts
Thanks
Re: How to modify a standard RAMPS 1.4 to work with Arduino Due? April 20, 2015 07:47AM |
enif
I followed your instructions to modify a RAMPS board and configured/loaded Marlin4Due on my Arduino Due - and now it is already doing the first test print! So far everything seems to work nicely
I only had one problem, but it was not related to the modifications, but to Marlin4Due, which did not like my X-MAX endstop. It homed ok to the right, but then thought it was at 0, so only allowed going further right, i.e. bumping into the endstop. As it turns out, Marlin4Due seems not to like the "G28 X0" command issued by pronterface for "Home X". But after changing that to "G28 X", it now works fine.
| Triffid Hunter's Calibration Guide | --> X <-- Drill for new Monitor | Most important Gcode. |
Re: How to modify a standard RAMPS 1.4 to work with Arduino Due? April 20, 2015 11:06AM |
Re: How to modify a standard RAMPS 1.4 to work with Arduino Due? April 20, 2015 12:46PM |
Re: How to modify a standard RAMPS 1.4 to work with Arduino Due? April 20, 2015 12:56PM |
Re: How to modify a standard RAMPS 1.4 to work with Arduino Due? April 20, 2015 04:20PM |
Re: How to modify a standard RAMPS 1.4 to work with Arduino Due? April 21, 2015 02:34AM |
Re: How to modify a standard RAMPS 1.4 to work with Arduino Due? April 24, 2015 02:23AM |
Re: How to modify a standard RAMPS 1.4 to work with Arduino Due? April 30, 2015 10:53PM |
