Re: How to modify a standard RAMPS 1.4 to work with Arduino Due? May 06, 2015 06:28AM |
dc42
Now suppose we have a device with the maximum 2.5V gate threshold voltage. To a first approximation, we have lost 0.5V gate drive. So to account for the worst case, we should use the 2.5V curve. That shows that the device would drop about 15V @ 10A! I stress that this only gives a rough idea of the worst case, it is not precise.
Re: How to modify a standard RAMPS 1.4 to work with Arduino Due? May 06, 2015 07:55AM |
bianchifan
Yesterday I took a look at RADDS's, it uses a BUK954R8.
Unfortunately Conrad doesn't sell those....
Re: How to modify a standard RAMPS 1.4 to work with Arduino Due? May 06, 2015 11:27AM |
Re: How to modify a standard RAMPS 1.4 to work with Arduino Due? May 06, 2015 01:06PM |
dc42
That mosfet doesn't give any Rds(on) data for Vgs=3V either.
Re: How to modify a standard RAMPS 1.4 to work with Arduino Due? May 06, 2015 01:23PM |
Re: How to modify a standard RAMPS 1.4 to work with Arduino Due? May 06, 2015 01:34PM |
Admin Registered: 18 years ago Posts: 7,883 |
Re: How to modify a standard RAMPS 1.4 to work with Arduino Due? May 06, 2015 04:47PM |
Re: How to modify a standard RAMPS 1.4 to work with Arduino Due? May 06, 2015 05:29PM |
Re: How to modify a standard RAMPS 1.4 to work with Arduino Due? May 06, 2015 05:53PM |
Re: How to modify a standard RAMPS 1.4 to work with Arduino Due? May 06, 2015 07:09PM |
pgScorpio
The IRLZ44N Does the job too (maybe even better).
55V / 25A @Vgs = 3.3v
VGS(th) Gate Threshold Voltage 1.0 – 2.0 V !
Re: How to modify a standard RAMPS 1.4 to work with Arduino Due? May 25, 2015 12:57PM |
Re: How to modify a standard RAMPS 1.4 to work with Arduino Due? May 25, 2015 01:48PM |
f3rDz
will there be any other modifications to do if i will be supplying 24v on the hacked ramps?
i'm not that knowledgeable in electronics
Re: How to modify a standard RAMPS 1.4 to work with Arduino Due? May 25, 2015 01:52PM |
Re: How to modify a standard RAMPS 1.4 to work with Arduino Due? May 25, 2015 07:34PM |
Re: How to modify a standard RAMPS 1.4 to work with Arduino Due? May 25, 2015 08:29PM |
AndrewBCN
f3rDz
There are a few threads in this forum about using 24V with a RAMPS 1.4, but basically the RAMPS was designed for 12V operation, 24V operation is considered experimental and unsupported. IMO it also has practically zero benefits for RepRap use and adds considerable reliability and safety concerns.
If you are already modifying a RAMPS for use with a Due I strongly advise AGAINST using 24V.
Re: How to modify a standard RAMPS 1.4 to work with Arduino Due? May 26, 2015 02:54AM |
f3rDz
well i guess i have to throw away those 24v heated bed and heater cartridges.
Re: How to modify a standard RAMPS 1.4 to work with Arduino Due? May 26, 2015 07:50AM |
Re: How to modify a standard RAMPS 1.4 to work with Arduino Due? May 26, 2015 11:09AM |
f3rDz
AndrewBCN
f3rDz
thanks andy
| Triffid Hunter's Calibration Guide | --> X <-- Drill for new Monitor | Most important Gcode. |
Re: How to modify a standard RAMPS 1.4 to work with Arduino Due? May 26, 2015 01:03PM |
Wurstnase
You must not. I used long time a solid state relay for my heatbed. This should also work great for a hotend.
Re: How to modify a standard RAMPS 1.4 to work with Arduino Due? May 26, 2015 02:44PM |
Re: How to modify a standard RAMPS 1.4 to work with Arduino Due? May 26, 2015 06:27PM |
Re: How to modify a standard RAMPS 1.4 to work with Arduino Due? May 27, 2015 07:14AM |
If you are not familiar with electronics maybe it's not the best idea..Quote
f3rDz
Re: How to modify a standard RAMPS 1.4 to work with Arduino Due? May 27, 2015 07:42AM |
Re: How to modify a standard RAMPS 1.4 to work with Arduino Due? May 27, 2015 08:20AM |
AndrewBCN
Well, we had two digressions in this thread:
1) Choice of 3.3V logic compatible MOSFET: conclusion, the IRLB8743 ($0.80) should work fine and the IRLB3034 ($1) should work fine too, perhaps even better.
2) Using 24V on a RAMPS modified for Due operation: just don't (and if you want to continue discussing this, please create a separate thread).
Hopefully we can go back to the main topic.
Re: How to modify a standard RAMPS 1.4 to work with Arduino Due? May 27, 2015 08:37AM |
Re: How to modify a standard RAMPS 1.4 to work with Arduino Due? May 27, 2015 08:38AM |
Re: How to modify a standard RAMPS 1.4 to work with Arduino Due? May 27, 2015 09:04AM |
bigfilsing
Anybody have any tips on Mosfet removal ?
, as in it takes me a good 15 minutes to remove one and properly clean the through holes, but just 1 minute to solder the new one in.
Re: How to modify a standard RAMPS 1.4 to work with Arduino Due? May 27, 2015 10:36AM |
Re: How to modify a standard RAMPS 1.4 to work with Arduino Due? May 27, 2015 11:23AM |
Re: How to modify a standard RAMPS 1.4 to work with Arduino Due? May 27, 2015 12:04PM |
