Re: How to modify a standard RAMPS 1.4 to work with Arduino Due?![]() December 11, 2015 06:48PM |
Re: How to modify a standard RAMPS 1.4 to work with Arduino Due?![]() February 16, 2016 09:58AM |
22:10:42.965 : OpenGL version:4.3.0 - Build 20.19.15.4331
22:10:42.965 : OpenGL extensions:GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_blend_color GL_EXT_abgr GL_EXT_texture3D GL_EXT_clip_volume_hint GL_EXT_compiled_vertex_array GL_SGIS_texture_edge_clamp GL_SGIS_generate_mipmap GL_EXT_draw_range_elements GL_SGIS_texture_lod GL_EXT_rescale_normal GL_EXT_packed_pixels GL_EXT_texture_edge_clamp GL_EXT_separate_specular_color GL_ARB_multitexture GL_ARB_map_buffer_alignment GL_ARB_conservative_depth GL_EXT_texture_env_combine GL_EXT_bgra GL_EXT_blend_func_separate GL_EXT_secondary_color GL_EXT_fog_coord GL_EXT_texture_env_add GL_ARB_texture_cube_map GL_ARB_transpose_matrix GL_ARB_internalformat_query GL_ARB_internalformat_query2 GL_ARB_texture_env_add GL_IBM_texture_mirrored_repeat GL_ARB_texture_mirrored_repeat GL_EXT_multi_draw_arrays GL_SUN_multi_draw_arrays GL_NV_blend_square GL_ARB_texture_compression GL_3DFX_texture_compression_FXT1 GL_EXT_texture_filter_anisotropic GL_ARB_texture_border_clamp GL_ARB_point_parameters GL_ARB_texture_env_combine GL_ARB_texture_env_dot3 GL_ARB_texture_env_crossbar GL_EXT_texture_compression_s3tc GL_ARB_shadow GL_ARB_window_pos GL_EXT_shadow_funcs GL_EXT_stencil_wrap GL_ARB_vertex_program GL_EXT_texture_rectangle GL_ARB_fragment_program GL_EXT_stencil_two_side GL_ATI_separate_stencil GL_ARB_vertex_buffer_object GL_EXT_texture_lod_bias GL_ARB_occlusion_query GL_ARB_fragment_shader GL_ARB_shader_objects GL_ARB_shading_language_100 GL_ARB_texture_non_power_of_two GL_ARB_vertex_shader GL_NV_texgen_reflection GL_ARB_point_sprite GL_ARB_fragment_program_shadow GL_EXT_blend_equation_separate GL_ARB_depth_texture GL_ARB_texture_rectangle GL_ARB_draw_buffers GL_ARB_color_buffer_float GL_ARB_half_float_pixel GL_ARB_texture_float GL_ARB_pixel_buffer_object GL_EXT_framebuffer_object GL_ARB_draw_instanced GL_ARB_half_float_vertex GL_ARB_occlusion_query2 GL_EXT_draw_buffers2 GL_WIN_swap_hint GL_EXT_texture_sRGB GL_ARB_multisample GL_EXT_packed_float GL_EXT_texture_shared_exponent GL_ARB_texture_rg GL_ARB_texture_compression_rgtc GL_NV_conditional_render GL_ARB_texture_swizzle GL_EXT_texture_swizzle GL_ARB_texture_gather GL_ARB_sync GL_ARB_cl_event GL_ARB_framebuffer_sRGB GL_EXT_packed_depth_stencil GL_ARB_depth_buffer_float GL_EXT_transform_feedback GL_ARB_transform_feedback2 GL_ARB_draw_indirect GL_EXT_framebuffer_blit GL_EXT_framebuffer_multisample GL_ARB_framebuffer_object GL_ARB_framebuffer_no_attachments GL_EXT_texture_array GL_EXT_texture_integer GL_ARB_map_buffer_range GL_ARB_texture_buffer_range GL_EXT_texture_snorm GL_ARB_blend_func_extended GL_INTEL_performance_query GL_ARB_copy_buffer GL_ARB_sampler_objects GL_NV_primitive_restart GL_ARB_seamless_cube_map GL_ARB_seamless_cubemap_per_texture GL_ARB_uniform_buffer_object GL_ARB_depth_clamp GL_ARB_vertex_array_bgra GL_ARB_shader_bit_encoding GL_ARB_draw_buffers_blend GL_ARB_geometry_shader4 GL_EXT_geometry_shader4 GL_ARB_texture_query_lod GL_ARB_explicit_attrib_location GL_ARB_draw_elements_base_vertex GL_EXT_shader_integer_mix GL_ARB_instanced_arrays GL_ARB_base_instance GL_ARB_fragment_coord_conventions GL_EXT_gpu_program_parameters GL_ARB_texture_buffer_object_rgb32 GL_ARB_compatibility GL_ARB_texture_rgb10_a2ui GL_ARB_texture_multisample GL_ARB_vertex_type_2_10_10_10_rev GL_ARB_vertex_type_10f_11f_11f_rev GL_ARB_timer_query GL_ARB_tessellation_shader GL_ARB_vertex_array_object GL_ARB_provoking_vertex GL_ARB_sample_shading GL_ARB_texture_cube_map_array GL_EXT_gpu_shader4 GL_ARB_gpu_shader5 GL_ARB_gpu_shader_fp64 GL_INTEL_fragment_shader_ordering GL_ARB_fragment_shader_interlock GL_ARB_clip_control GL_ARB_shader_subroutine GL_ARB_transform_feedback3 GL_ARB_get_program_binary GL_ARB_separate_shader_objects GL_ARB_shader_precision GL_ARB_vertex_attrib_64bit GL_ARB_viewport_array GL_ARB_transform_feedback_instanced GL_ARB_compressed_texture_pixel_storage GL_ARB_shader_atomic_counters GL_ARB_shading_language_packing GL_ARB_shader_image_load_store GL_ARB_shading_language_420pack GL_ARB_texture_storage GL_EXT_texture_storage GL_ARB_compute_shader GL_ARB_vertex_attrib_binding GL_ARB_texture_view GL_ARB_fragment_layer_viewport GL_ARB_multi_draw_indirect GL_ARB_program_interface_query GL_ARB_shader_image_size GL_ARB_shader_storage_buffer_object GL_ARB_texture_storage_multisample GL_ARB_buffer_storage GL_AMD_vertex_shader_layer GL_AMD_vertex_shader_viewport_index GL_ARB_query_buffer_object GL_EXT_polygon_offset_clamp GL_ARB_clear_texture GL_ARB_texture_mirror_clamp_to_edge GL_ARB_debug_output GL_ARB_enhanced_layouts GL_KHR_debug GL_ARB_arrays_of_arrays GL_ARB_texture_query_levels GL_ARB_invalidate_subdata GL_ARB_clear_buffer_object GL_INTEL_map_texture GL_ARB_texture_compression_bptc GL_ARB_ES2_compatibility GL_ARB_ES3_compatibility GL_ARB_robustness GL_ARB_robust_buffer_access_behavior GL_EXT_texture_sRGB_decode GL_ARB_copy_image GL_KHR_blend_equation_advanced GL_EXT_direct_state_access GL_ARB_stencil_texturing GL_ARB_texture_stencil8 GL_ARB_explicit_uniform_location GL_ARB_multi_bind GL_ARB_indirect_parameters
22:10:42.965 : OpenGL renderer:Intel(R) HD Graphics 4600
22:10:42.965 : Using fast VBOs for rendering is possible
22:10:49.422 : Printer reset detected - initalizing
22:10:49.424 : start
22:10:49.424 : Info: PowerUp
22:10:49.427 : MK4due_4.2.5_dev
22:10:49.427 : Last Updated: Feb 15 2016 18:05:55 | Author: (none, default config)
22:10:49.427 : Compiled: Feb 15 2016
22:10:49.431 : Free Memory: 87948 PlannerBufferBytes: 2688
22:10:49.435 : Echo: Hardcoded Default Settings Loaded
22:10:49.435 : Config: Steps per unit:
22:10:49.435 : Config: M92 X160.00 Y160.00 Z160.00 E625.00
22:10:49.439 : Config: Maximum feedrates (mm/s):
22:10:49.439 : Config: M203 X500.00 Y500.00 Z500.00 E100.00
22:10:49.443 : Config: Maximum Acceleration (mm/s2):
22:10:49.443 : Config: M201 X5000 Y5000 Z5000 E1000
22:10:49.447 : Config: Accelerations: P=printing, V=travel and T* R=retract
22:10:49.447 : Config: M204 P3000.00 V3000.00
22:10:49.448 : Config: M204 T0 R10000.00
22:10:49.456 : Config: Advanced variables: S=Min feedrate (mm/s), V=Min travel feedrate (mm/s), B=minimum segment time (ms), X=maximum XY jerk (mm/s), Z=maximum Z jerk (mm/s), E=maximum E jerk (mm/s)
22:10:49.460 : Config: M205 S0.00 V0.00 B20000 X20.00 Z20.00 E5.00
22:10:49.460 : Config: Home offset (mm):
22:10:49.460 : Config: M206 X0.00 Y0.00 Z0.00
22:10:49.460 : Config: Delta Geometry adjustment:
22:10:49.468 : Config: M666 A0.000 B0.000 C0.000 I0.000 J0.000 K0.000 U0.000 V0.000 W0.000 R119.52 D350.00 H200.00
22:10:49.468 : Config: Endstop Offsets:
22:10:49.468 : Config: M666 X0.00 Y0.00 Z0.00
22:10:49.468 : Config: Z-Probe Offset:
22:10:49.472 : Config: M666 P X24.00 Y14.00 Z-1.00
22:10:49.472 : Config: PID settings:
22:10:49.472 : Config: M301 H0 P40.00 I7.00 D60.00
22:10:49.476 : Config: Filament settings: Disabled
22:10:49.476 : Info: Power on time:
22:10:49.476 : Info: 0 days 0 hours 0 minutes
22:10:49.476 : Info: Filament printed:
22:10:49.480 : Info: 0 Km 0 m 0 cm 0 mm
22:10:49.480 : First start for temperature finished.
22:10:49.643 : N1 M110*34
22:10:49.643 : N2 M115*36
22:10:49.643 : N3 M105*36
22:10:49.643 : N4 M114*35
22:10:49.643 : N5 M111 S6*98
22:10:49.656 : N6 T0*60
22:10:49.656 : N7 M20*22
22:10:49.657 : N8 M80*19
22:10:49.657 : N9 M105*46
22:10:49.731 : Error: Unknown command: "
22:10:52.693 : N10 M105*22
22:10:55.756 : N11 M105*23
Re: How to modify a standard RAMPS 1.4 to work with Arduino Due?![]() March 19, 2016 06:35AM |
Try changing transfer protocol to ASCII, or lower the baudrate.Quote
campe89
Hi guys, after the ramps mods,I have flash the Marlinkimbra4due firmware [github.com] but repetier-host report this error message:
22:10:42.965 : OpenGL version:4.3.0 - Build 20.19.15.4331 22:10:42.965 : OpenGL extensions:GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_blend_color GL_EXT_abgr GL_EXT_texture3D GL_EXT_clip_volume_hint GL_EXT_compiled_vertex_array GL_SGIS_texture_edge_clamp GL_SGIS_generate_mipmap GL_EXT_draw_range_elements GL_SGIS_texture_lod GL_EXT_rescale_normal GL_EXT_packed_pixels GL_EXT_texture_edge_clamp GL_EXT_separate_specular_color GL_ARB_multitexture GL_ARB_map_buffer_alignment GL_ARB_conservative_depth GL_EXT_texture_env_combine GL_EXT_bgra GL_EXT_blend_func_separate GL_EXT_secondary_color GL_EXT_fog_coord GL_EXT_texture_env_add GL_ARB_texture_cube_map GL_ARB_transpose_matrix GL_ARB_internalformat_query GL_ARB_internalformat_query2 GL_ARB_texture_env_add GL_IBM_texture_mirrored_repeat GL_ARB_texture_mirrored_repeat GL_EXT_multi_draw_arrays GL_SUN_multi_draw_arrays GL_NV_blend_square GL_ARB_texture_compression GL_3DFX_texture_compression_FXT1 GL_EXT_texture_filter_anisotropic GL_ARB_texture_border_clamp GL_ARB_point_parameters GL_ARB_texture_env_combine GL_ARB_texture_env_dot3 GL_ARB_texture_env_crossbar GL_EXT_texture_compression_s3tc GL_ARB_shadow GL_ARB_window_pos GL_EXT_shadow_funcs GL_EXT_stencil_wrap GL_ARB_vertex_program GL_EXT_texture_rectangle GL_ARB_fragment_program GL_EXT_stencil_two_side GL_ATI_separate_stencil GL_ARB_vertex_buffer_object GL_EXT_texture_lod_bias GL_ARB_occlusion_query GL_ARB_fragment_shader GL_ARB_shader_objects GL_ARB_shading_language_100 GL_ARB_texture_non_power_of_two GL_ARB_vertex_shader GL_NV_texgen_reflection GL_ARB_point_sprite GL_ARB_fragment_program_shadow GL_EXT_blend_equation_separate GL_ARB_depth_texture GL_ARB_texture_rectangle GL_ARB_draw_buffers GL_ARB_color_buffer_float GL_ARB_half_float_pixel GL_ARB_texture_float GL_ARB_pixel_buffer_object GL_EXT_framebuffer_object GL_ARB_draw_instanced GL_ARB_half_float_vertex GL_ARB_occlusion_query2 GL_EXT_draw_buffers2 GL_WIN_swap_hint GL_EXT_texture_sRGB GL_ARB_multisample GL_EXT_packed_float GL_EXT_texture_shared_exponent GL_ARB_texture_rg GL_ARB_texture_compression_rgtc GL_NV_conditional_render GL_ARB_texture_swizzle GL_EXT_texture_swizzle GL_ARB_texture_gather GL_ARB_sync GL_ARB_cl_event GL_ARB_framebuffer_sRGB GL_EXT_packed_depth_stencil GL_ARB_depth_buffer_float GL_EXT_transform_feedback GL_ARB_transform_feedback2 GL_ARB_draw_indirect GL_EXT_framebuffer_blit GL_EXT_framebuffer_multisample GL_ARB_framebuffer_object GL_ARB_framebuffer_no_attachments GL_EXT_texture_array GL_EXT_texture_integer GL_ARB_map_buffer_range GL_ARB_texture_buffer_range GL_EXT_texture_snorm GL_ARB_blend_func_extended GL_INTEL_performance_query GL_ARB_copy_buffer GL_ARB_sampler_objects GL_NV_primitive_restart GL_ARB_seamless_cube_map GL_ARB_seamless_cubemap_per_texture GL_ARB_uniform_buffer_object GL_ARB_depth_clamp GL_ARB_vertex_array_bgra GL_ARB_shader_bit_encoding GL_ARB_draw_buffers_blend GL_ARB_geometry_shader4 GL_EXT_geometry_shader4 GL_ARB_texture_query_lod GL_ARB_explicit_attrib_location GL_ARB_draw_elements_base_vertex GL_EXT_shader_integer_mix GL_ARB_instanced_arrays GL_ARB_base_instance GL_ARB_fragment_coord_conventions GL_EXT_gpu_program_parameters GL_ARB_texture_buffer_object_rgb32 GL_ARB_compatibility GL_ARB_texture_rgb10_a2ui GL_ARB_texture_multisample GL_ARB_vertex_type_2_10_10_10_rev GL_ARB_vertex_type_10f_11f_11f_rev GL_ARB_timer_query GL_ARB_tessellation_shader GL_ARB_vertex_array_object GL_ARB_provoking_vertex GL_ARB_sample_shading GL_ARB_texture_cube_map_array GL_EXT_gpu_shader4 GL_ARB_gpu_shader5 GL_ARB_gpu_shader_fp64 GL_INTEL_fragment_shader_ordering GL_ARB_fragment_shader_interlock GL_ARB_clip_control GL_ARB_shader_subroutine GL_ARB_transform_feedback3 GL_ARB_get_program_binary GL_ARB_separate_shader_objects GL_ARB_shader_precision GL_ARB_vertex_attrib_64bit GL_ARB_viewport_array GL_ARB_transform_feedback_instanced GL_ARB_compressed_texture_pixel_storage GL_ARB_shader_atomic_counters GL_ARB_shading_language_packing GL_ARB_shader_image_load_store GL_ARB_shading_language_420pack GL_ARB_texture_storage GL_EXT_texture_storage GL_ARB_compute_shader GL_ARB_vertex_attrib_binding GL_ARB_texture_view GL_ARB_fragment_layer_viewport GL_ARB_multi_draw_indirect GL_ARB_program_interface_query GL_ARB_shader_image_size GL_ARB_shader_storage_buffer_object GL_ARB_texture_storage_multisample GL_ARB_buffer_storage GL_AMD_vertex_shader_layer GL_AMD_vertex_shader_viewport_index GL_ARB_query_buffer_object GL_EXT_polygon_offset_clamp GL_ARB_clear_texture GL_ARB_texture_mirror_clamp_to_edge GL_ARB_debug_output GL_ARB_enhanced_layouts GL_KHR_debug GL_ARB_arrays_of_arrays GL_ARB_texture_query_levels GL_ARB_invalidate_subdata GL_ARB_clear_buffer_object GL_INTEL_map_texture GL_ARB_texture_compression_bptc GL_ARB_ES2_compatibility GL_ARB_ES3_compatibility GL_ARB_robustness GL_ARB_robust_buffer_access_behavior GL_EXT_texture_sRGB_decode GL_ARB_copy_image GL_KHR_blend_equation_advanced GL_EXT_direct_state_access GL_ARB_stencil_texturing GL_ARB_texture_stencil8 GL_ARB_explicit_uniform_location GL_ARB_multi_bind GL_ARB_indirect_parameters 22:10:42.965 : OpenGL renderer:Intel(R) HD Graphics 4600 22:10:42.965 : Using fast VBOs for rendering is possible 22:10:49.422 : Printer reset detected - initalizing 22:10:49.424 : start 22:10:49.424 : Info: PowerUp 22:10:49.427 : MK4due_4.2.5_dev 22:10:49.427 : Last Updated: Feb 15 2016 18:05:55 | Author: (none, default config) 22:10:49.427 : Compiled: Feb 15 2016 22:10:49.431 : Free Memory: 87948 PlannerBufferBytes: 2688 22:10:49.435 : Echo: Hardcoded Default Settings Loaded 22:10:49.435 : Config: Steps per unit: 22:10:49.435 : Config: M92 X160.00 Y160.00 Z160.00 E625.00 22:10:49.439 : Config: Maximum feedrates (mm/s): 22:10:49.439 : Config: M203 X500.00 Y500.00 Z500.00 E100.00 22:10:49.443 : Config: Maximum Acceleration (mm/s2): 22:10:49.443 : Config: M201 X5000 Y5000 Z5000 E1000 22:10:49.447 : Config: Accelerations: P=printing, V=travel and T* R=retract 22:10:49.447 : Config: M204 P3000.00 V3000.00 22:10:49.448 : Config: M204 T0 R10000.00 22:10:49.456 : Config: Advanced variables: S=Min feedrate (mm/s), V=Min travel feedrate (mm/s), B=minimum segment time (ms), X=maximum XY jerk (mm/s), Z=maximum Z jerk (mm/s), E=maximum E jerk (mm/s) 22:10:49.460 : Config: M205 S0.00 V0.00 B20000 X20.00 Z20.00 E5.00 22:10:49.460 : Config: Home offset (mm): 22:10:49.460 : Config: M206 X0.00 Y0.00 Z0.00 22:10:49.460 : Config: Delta Geometry adjustment: 22:10:49.468 : Config: M666 A0.000 B0.000 C0.000 I0.000 J0.000 K0.000 U0.000 V0.000 W0.000 R119.52 D350.00 H200.00 22:10:49.468 : Config: Endstop Offsets: 22:10:49.468 : Config: M666 X0.00 Y0.00 Z0.00 22:10:49.468 : Config: Z-Probe Offset: 22:10:49.472 : Config: M666 P X24.00 Y14.00 Z-1.00 22:10:49.472 : Config: PID settings: 22:10:49.472 : Config: M301 H0 P40.00 I7.00 D60.00 22:10:49.476 : Config: Filament settings: Disabled 22:10:49.476 : Info: Power on time: 22:10:49.476 : Info: 0 days 0 hours 0 minutes 22:10:49.476 : Info: Filament printed: 22:10:49.480 : Info: 0 Km 0 m 0 cm 0 mm 22:10:49.480 : First start for temperature finished. 22:10:49.643 : N1 M110*34 22:10:49.643 : N2 M115*36 22:10:49.643 : N3 M105*36 22:10:49.643 : N4 M114*35 22:10:49.643 : N5 M111 S6*98 22:10:49.656 : N6 T0*60 22:10:49.656 : N7 M20*22 22:10:49.657 : N8 M80*19 22:10:49.657 : N9 M105*46 22:10:49.731 : Error: Unknown command: " 22:10:52.693 : N10 M105*22 22:10:55.756 : N11 M105*23
I can't read temperatures, I can't send any commands, and D8, D9, D10 output are always on. Any idea?
I think I made all the mods correctly.
Re: How to modify a standard RAMPS 1.4 to work with Arduino Due?![]() June 18, 2016 05:29AM |
Re: How to modify a standard RAMPS 1.4 to work with Arduino Due?![]() July 08, 2016 08:35AM |
bobc
With RAMPS 1.4 now selling for as low as $5 incl shipping, I think it is a pretty interesting mod. Did anyone put together a web page describing the mods? If not I might do that.
I am just doing a KiCad version of RAMPS 1.4.2, so could also do a schematic for a 3.3V version.
Re: How to modify a standard RAMPS 1.4 to work with Arduino Due?![]() July 09, 2016 06:55AM |
Re: How to modify a standard RAMPS 1.4 to work with Arduino Due?![]() July 09, 2016 12:40PM |
dc42
IMO, so-called SMART RAMPS is just as dumb as the original. It still has no on-board 5V regulator to power GLCDs without overloading the 5V regulator on the Arduino, and it still has a poorly-chosen bed heater mosfet. What a wasted opportunity.
Re: How to modify a standard RAMPS 1.4 to work with Arduino Due?![]() July 09, 2016 01:55PM |
bobc
dc42
You never tire of knocking other people's work do you?
It seems you post just to get another plug in for your products.
If you've nothing constructive, please go away.
Re: How to modify a standard RAMPS 1.4 to work with Arduino Due?![]() August 05, 2016 03:10AM |
dc42
I am offering constructive criticism, because RAMPS has been stuck in a rut for years and badly needs to be improved. I don't knock other people's work when it is good.
Poor electronic design really irritates me. But when a design has more than one well-known flaw, yet none of them are addressed when the design is revised, that is IMO inexcusable.
The SMART tag on RAMPS 1.4.1 is a total joke.
Re: How to modify a standard RAMPS 1.4 to work with Arduino Due?![]() August 05, 2016 05:37PM |
Re: How to modify a standard RAMPS 1.4 to work with Arduino Due?![]() July 15, 2017 09:14PM |
Re: How to modify a standard RAMPS 1.4 to work with Arduino Due?![]() August 03, 2017 04:41AM |
Re: How to modify a standard RAMPS 1.4 to work with Arduino Due?![]() August 03, 2017 06:28AM |
Admin Registered: 12 years ago Posts: 6,789 |
Re: How to modify a standard RAMPS 1.4 to work with Arduino Due?![]() August 03, 2017 12:10PM |
Re: How to modify a standard RAMPS 1.4 to work with Arduino Due?![]() November 18, 2017 10:28AM |
Re: How to modify a standard RAMPS 1.4 to work with Arduino Due?![]() November 19, 2017 10:26PM |
Re: How to modify a standard RAMPS 1.4 to work with Arduino Due?![]() November 19, 2017 10:35PM |
Re: How to modify a standard RAMPS 1.4 to work with Arduino Due?![]() January 08, 2018 07:59AM |
Re: How to modify a standard RAMPS 1.4 to work with Arduino Due?![]() January 09, 2018 12:42AM |
Re: How to modify a standard RAMPS 1.4 to work with Arduino Due?![]() January 09, 2018 07:59AM |
Re: How to modify a standard RAMPS 1.4 to work with Arduino Due?![]() June 01, 2018 03:23PM |
Re: How to modify a standard RAMPS 1.4 to work with Arduino Due?![]() June 06, 2018 03:44PM |
Re: How to modify a standard RAMPS 1.4 to work with Arduino Due?![]() June 12, 2018 05:55PM |
Re: How to modify a standard RAMPS 1.4 to work with Arduino Due?![]() June 18, 2018 04:36AM |
Re: How to modify a standard RAMPS 1.4 to work with Arduino Due?![]() April 08, 2019 08:22AM |
Re: How to modify a standard RAMPS 1.4 to work with Arduino Due?![]() April 09, 2019 03:22AM |
carro
Hi all.
Built myself one tooIt's running fine under Marlin 2 but I'd like to experiment with it. Has anyone tried to install ReprapFirmware on a Due? Is it possible to use Due+RAMPS and RRF? Any pointers where to start much appreciated.
Re: How to modify a standard RAMPS 1.4 to work with Arduino Due?![]() April 09, 2019 05:41AM |
Admin Registered: 15 years ago Posts: 13,764 |
Re: How to modify a standard RAMPS 1.4 to work with Arduino Due?![]() April 09, 2019 06:06AM |
Re: How to modify a standard RAMPS 1.4 to work with Arduino Due?![]() April 09, 2019 03:03PM |
VDX
@dc42
... I'm running some machines with RADDS or compatible 4-axis-drivers, actually with Marlin4Due, but regularly modifying the firmware or searching for alternatives -- so could test your RRF
Re: How to modify a standard RAMPS 1.4 to work with Arduino Due?![]() April 09, 2019 03:43PM |
