Adafruit ST7565 LCD and Ramps 1.4 March 08, 2015 02:38PM |
Re: Adafruit ST7565 LCD and Ramps 1.4 March 08, 2015 06:27PM |
Re: Adafruit ST7565 LCD and Ramps 1.4 March 08, 2015 11:34PM |
Re: Adafruit ST7565 LCD and Ramps 1.4 March 09, 2015 01:21AM |
Re: Adafruit ST7565 LCD and Ramps 1.4 March 09, 2015 06:39PM |
Re: Adafruit ST7565 LCD and Ramps 1.4 March 09, 2015 09:31PM |
Re: Adafruit ST7565 LCD and Ramps 1.4 March 09, 2015 09:54PM |
Re: Adafruit ST7565 LCD and Ramps 1.4 March 10, 2015 02:34AM |
AndrewBCN
The main point here is that the Adafruit display you mention uses SPI whereas the Full Graphics display uses 4-bit parallel communication. It makes no sense for you to try to use the Full Graphics routines and pin assignment in Marlin for the Adafruit display.
Re: Adafruit ST7565 LCD and Ramps 1.4 March 10, 2015 08:52AM |
Re: Adafruit ST7565 LCD and Ramps 1.4 March 10, 2015 06:11PM |
Re: Adafruit ST7565 LCD and Ramps 1.4 March 10, 2015 06:19PM |
Re: Adafruit ST7565 LCD and Ramps 1.4 March 10, 2015 10:03PM |
Re: Adafruit ST7565 LCD and Ramps 1.4 March 10, 2015 10:19PM |
Re: Adafruit ST7565 LCD and Ramps 1.4 March 10, 2015 11:30PM |
Re: Adafruit ST7565 LCD and Ramps 1.4 March 10, 2015 11:43PM |
Re: Adafruit ST7565 LCD and Ramps 1.4 March 10, 2015 11:46PM |
Re: Adafruit ST7565 LCD and Ramps 1.4 March 22, 2015 07:42AM |
Re: Adafruit ST7565 LCD and Ramps 1.4 March 22, 2015 08:54AM |
NarimaanV
Hi ElmoC,
I'm actually planning on getting this same display to both teach myself how these full graphic LCD's run and if possible (which after finding this, apparently it is) connect it to my RAMPS board. Would you be willing to share the changes you had to make to Marlin and the pin connections from the LCD pins to the RAMPS board pins?
Re: Adafruit ST7565 LCD and Ramps 1.4 March 22, 2015 09:24AM |
