when I move X axis manual, Y axis moves with it!! April 04, 2015 10:37AM |
Re: when I move X axis manual, Y axis moves with it!! April 04, 2015 02:24PM |
Re: when I move X axis manual, Y axis moves with it!! April 05, 2015 03:56PM |
Re: when I move X axis manual, Y axis moves with it!! April 05, 2015 08:50PM |
Re: when I move X axis manual, Y axis moves with it!! April 07, 2015 08:29PM |
jatmega
Hi
It would really help if you could attach the marlin files configuration.h and configuration_adv.h, and a picture of the motor wiring to the ramps board.
That way it will be a lot easier to troubleshoot it.
Can you describe more in detail how you manually moved the axis?
like step by step menu selection on the 3D-printer.
Hope we can solve this
jatmega
Re: when I move X axis manual, Y axis moves with it!! April 08, 2015 02:26AM |
... // Define this to set a custom name for your generic Mendel, #define CUSTOM_MENDEL_NAME "Cerberus MEGA" ... //=========================================================================== //============================== Delta Settings ============================= //=========================================================================== // Enable DELTA kinematics #define DELTA // Make delta curves from many straight lines (linear interpolation). // This is a trade-off between visible corners (not enough segments) // and processor overload (too many expensive sqrt calls). #define DELTA_SEGMENTS_PER_SECOND 200 ...
Re: when I move X axis manual, Y axis moves with it!! April 10, 2015 08:44PM |
