Heated bed keeps getting hotter while printing April 25, 2015 07:53AM |
Re: Heated bed keeps getting hotter while printing April 27, 2015 09:07AM |
Re: Heated bed keeps getting hotter while printing May 02, 2015 10:29AM |
Re: Heated bed keeps getting hotter while printing May 04, 2015 05:48PM |
Re: Heated bed keeps getting hotter while printing May 05, 2015 02:16AM |
Re: Heated bed keeps getting hotter while printing May 05, 2015 01:00PM |
Re: Heated bed keeps getting hotter while printing May 05, 2015 05:35PM |
Re: Heated bed keeps getting hotter while printing May 05, 2015 09:30PM |
tadawson
The only thing I see which makes me wonder, is that if it truly were a hardware issue, then why does it stop overheating when the job is terminated?
Re: Heated bed keeps getting hotter while printing May 06, 2015 11:38AM |
The reason why this happened as it did is the metal tab is the same as the drain pin on most MOSFETs. When they touched you were allowing either or both MOSFETs to serve as the switch to turn on and off both circuits involved.Quote
LarsK
I had a similar issue when the heatsink for the heated-bed was touching the heatsink for the extruder. See if the two mosfets backsides are maybe touching each other? It would Murphy law type of thing because you tried two RAMPS but worth checking anyways...
Re: Heated bed keeps getting hotter while printing May 07, 2015 03:15PM |
Re: Heated bed keeps getting hotter while printing July 13, 2015 07:20PM |
