Fried Mega 2560 with RAMPS 1.4 May 18, 2015 04:29AM |
Re: Fried Mega 2560 with RAMPS 1.4 May 18, 2015 05:35AM |
Re: Fried Mega 2560 with RAMPS 1.4 May 18, 2015 07:17AM |
Re: Fried Mega 2560 with RAMPS 1.4 May 23, 2015 02:03AM |
enif
The USB cable getting hot might also be due to some ground loop. So make sure that there is no significant voltage difference between the ground of your PS and the ground of the USB. Measure the voltage between the two grounds *before* both are connected via the controller. Is your PS connected to the same AC outlet as your PS?
Re: Fried Mega 2560 with RAMPS 1.4 May 23, 2015 02:32AM |
Re: Fried Mega 2560 with RAMPS 1.4 May 23, 2015 02:38AM |
gatorNic
Interesting I think I just had the same problem as this, although I haven't gone an purchased another board yet. Everything was fine until I plugged in both the power AND the usb, then pop hiss! Did you figure out the issue OP?
Re: Fried Mega 2560 with RAMPS 1.4 May 23, 2015 06:46PM |
tommy-b-10
Yup manage to work out that my psu wasn't grounded correctly, causing the voltage to be seen as wrong by the mega. Solution was to manually connect a cable between V- and ground on the psu.
Re: Fried Mega 2560 with RAMPS 1.4 May 24, 2015 11:56AM |
gatorNic
tommy-b-10
How did you figure out that it wasn't grounded correctly? So you put a wire between an open slot V- and the ground or did you wire it to the V- slot that was going to the MEGA? Although probably wouldn't matter I would guess.
Good to here you got it up and running! That's my worry is to order another board without solving the problem first. Need to do some testing.
Re: Fried Mega 2560 with RAMPS 1.4 July 04, 2015 09:51PM |
