Heatsink for the FETs May 25, 2015 08:30PM |
Re: Heatsink for the FETs May 26, 2015 12:25AM |
Re: Heatsink for the FETs May 26, 2015 02:21AM |
Re: Heatsink for the FETs May 26, 2015 07:26AM |
Re: Heatsink for the FETs May 26, 2015 07:46AM |
o_lampe
Kapton tape between heatsink and FET would insulate the sink. As long, as the screw to fix the heatsink doesn´t make contact.
-Olaf
Re: Heatsink for the FETs May 26, 2015 08:46AM |
Re: Heatsink for the FETs May 26, 2015 10:26AM |
cdru
Or the other option is to replace the mosfet with a better one that doesn't need active cooling to survive.
and does take a lot more work and time (about 20 minutes to unsolder the original MOSFET and solder the new one in, assuming average (de-)soldering skills, vs. 1 minute to install the small TO-220 heatsink). The advantage of a better MOSFET, besides dissipating less heat, is that it transfers more power to the heatbed i.e. it is more efficient as a switch.
Re: Heatsink for the FETs May 26, 2015 07:37PM |
Re: Heatsink for the FETs May 26, 2015 07:46PM |
Re: Heatsink for the FETs May 26, 2015 09:36PM |
Re: Heatsink for the FETs May 26, 2015 09:39PM |
itchytweed
Even a small fan blowing over the device will help as well.
Re: Heatsink for the FETs May 26, 2015 09:49PM |
