Motors make loud buzzing noise and wont turn.
June 03, 2015 11:15PM
So I am setting up my CoreXY build and the motors will not turn.. When I try to move them using Repetier Host, all that happens is they make a loud buzzing noise and vibrate. I have Vref set 0.8 V, which I would think is enough.
Here are the motors I am using: [www.ebay.com]
I am using DRV8825 drivers in a RAMPS 1.4 with Marlin.
Both motors do the same thing. and the z motor just doesn't move at all.
Any ideas what is wrong?
Thanks.
greghoge.com
HUGE 3D PRINTER PARTS SALE!!!
Re: Motors make loud buzzing noise and wont turn.
June 04, 2015 04:01AM
You might have the wrong connection order when you soldered your own extension cables?
For your RAMPS it is
2B 2A 1A 1B.
But your motors are
PIN1= B-
•PIN3= B
•PIN4= A
•PIN6= A-
So you should try
2B = B-
2A = A-
1A = A
1B = B
-Olaf
Edited 1 time(s). Last edit at 06/04/2015 04:06AM by o_lampe.
June 04, 2015 03:58PM
I didn't use extension cables., but I'll double check that because I think they wiring for my new motors is slightly different than the previous ones (which moved, albeit very roughly).
Edited 1 time(s). Last edit at 06/04/2015 03:59PM by gmh39.
greghoge.com
June 04, 2015 07:11PM
That was it. Took some guess and test, but finally got it.
greghoge.com
