Hello!
I'm working on getting my machine up and running using Marlin firmware - but I'm having some problems. The X-axis motor only moves to the left. This is slightly complicated by the fact that I'm using
Powerlolu stepper motor drivers
I have searched this forum and tried some of the suggestions with no luck so far -
- I have removed all the endstops and jumped the endstop pins together - sending M119 shows that all the endstops are open
- I have tried using the RAMPSTestCode.pde (everything lights up but the motor only moves in one direction)
- I've even switched out my motors and tried a different RAMPs board.
Does anyone have any experience with the powerlolu stepper driver? I suspect I'm wiring that incorrectly?
I'm particularly unclear about the circled GND and Voltage - I interpreted that wiring diagram as saying that if I'm using an external power supply (which I am - 24V) then don't use those lines at all
Thanks!
