Dual Y Axis Steppers June 09, 2015 01:15PM |
Re: Dual Y Axis Steppers June 09, 2015 01:51PM |
Re: Dual Y Axis Steppers June 09, 2015 03:27PM |
Re: Dual Y Axis Steppers June 09, 2015 06:33PM |
Re: Dual Y Axis Steppers June 09, 2015 09:18PM |
Re: Dual Y Axis Steppers June 09, 2015 10:16PM |
Re: Dual Y Axis Steppers June 09, 2015 11:53PM |
Re: Dual Y Axis Steppers June 10, 2015 01:15AM |
Re: Dual Y Axis Steppers June 10, 2015 03:59AM |
Re: Dual Y Axis Steppers June 10, 2015 04:17AM |
Re: Dual Y Axis Steppers June 10, 2015 04:22AM |
o_lampe
madmike8
You could wire them in series for NC, so that which ever endstop would hit would stop it.
Are you sure about the serial wiring?
I thought it through over and over again, and came to the conclusion, they had to be wired in parallel to build an "or"-function.
-Olaf
Re: Dual Y Axis Steppers June 10, 2015 09:44AM |
tadawson
o_lampe
madmike8
-Olaf
Not for normally closed (NC, as he mentioned) endstops. You would want parallel for normally open, though . . .
- Tim
Re: Dual Y Axis Steppers June 10, 2015 05:28PM |
If NO is common, so is NC. NC are generally recommended because if a switch should fail open, or a wire becomes disconnected, it will be seen as tripped and movement halted. A NO switch will appear the same whether it's connected or not, creating the potential for bad things to happen.Quote
o_lampe
OK, I expected NO switches, because IMHO that´s the common case.
Re: Dual Y Axis Steppers June 11, 2015 03:54AM |
