RAMPS 1.4 Problem
Posted by tim3716
RAMPS 1.4 Problem
June 18, 2015 10:30PM
Re: RAMPS 1.4 Problem
June 18, 2015 10:40PM
I accidentally made a duplicate post
June 19, 2015 04:46AM
tim3716
The video explains everything. https://www.youtube.com/watch?v=MVE3yV51MDg
IS D1 installed on the Ramps board is it in correctly and is it ok D1 provides the voltage to the Arduino from the Ramps supply
Other than that it may well be the Voltage Regulator on the arduino they are known to be fragile.
Doug
June 19, 2015 09:06AM
How do I test if it is installed correctly?
June 19, 2015 10:27AM
tim3716
See
D1 is shown in the centre of the pic make sure yours is in the same orientation (Stripe at the pwr connector end and if so you can measure it's Resistance it should be Low one way and high when you reverse your test meter leads.
HTH
Doug
June 19, 2015 11:02PM
I just tested it and It seems to be working fine.
June 20, 2015 04:59AM
It´s just a guts feeling, but you might have screwed up the mega-board, when you unsoldered the barrel connector. sad smiley
Check the area around the barrel for missing or misaligned SMD components.
-Olaf
