Second extruder causing temperature faults
Posted by abritton
July 20, 2015 04:59PM
I am in the process of getting a custom printer up and running and I have hit a snag. I just got the parts machined for a dual extruder setup. After getting everything mounted up and wired, I went into the firmware (Marlin) to add the second extruder. I changed the number of extruders to 2 and added the correct thermister table for the second thermister under temp sensor 1. However, when I connected using Repetier Host, the board is throwing a minimum temperature reset and neither thermistor is getting a reading anymore. I had another ramps board and tried swapping it but I got the same issue.. I have attached my configuration.h file for someone with a little more knowledge to look at. If there are any other settings in Marlin that may cause this that are not in configuration.h please let me know and I will check them as well.
open | download - configuration.txt (39.6 KB)
Re: Second extruder causing temperature faults
July 21, 2015 04:45AM
Why did you change the motherboard setting from 33 to 34 ( EFB to EEB ) when you don“t have a tempsensor specified for the bed?
You could try 36 ( EEF ) or define a tempsensor for the bed.
-Olaf
Edited 2 time(s). Last edit at 07/21/2015 04:50AM by o_lampe.
July 21, 2015 09:12AM
I do have a need for the third thermistor as well and have tried defining that one along with it. It causes the same error when I enable it.
July 21, 2015 10:22AM
Found the problem. Had an almost broken wire at the head of the thermistor that was causing false readings. Changed it out and now everything is up and running
