Printer halted. kill() called! July 30, 2015 03:47PM |
Connecting... start Printer is now online. echo:Marlin1.0.0 echo: Last Updated: Apr 11 2015 00:01:46 | Author: (none, default config) Compiled: Apr 11 2015 echo: Free Memory: 2878 PlannerBufferBytes: 1232 echo:Hardcoded Default Settings Loaded echoteps per unit: echo: M92 X52.49 Y52.49 Z2015.75 E476.00 echo:Maximum feedrates (mm/s): echo: M203 X500.00 Y500.00 Z5.00 E45.00 echo:Maximum Acceleration (mm/s2): echo: M201 X900 Y900 Z80 E10000 echo:Acceleration: S=acceleration, T=retract acceleration echo: M204 S3000.00 T3000.00 echo:Advanced variables: S=Min feedrate (mm/s), T=Min travel feedrate (mm/s), B=minimum segment time (ms), X=maximum XY jerk (mm/s), Z=maximum Z jerk (mm/s), E=maximum E jerk (mm/s) echo: M205 S0.00 T0.00 B20000 X20.00 Z0.40 E5.00 echo:Home offset (mm): echo: M206 X0.00 Y0.00 Z0.00 echo
ID settings: echo: M301 P41.47 I2.94 D146.07 echo
D init fail Error
Re: Printer halted. kill() called! July 30, 2015 06:08PM |
Re: Printer halted. kill() called! July 31, 2015 02:01PM |
Re: Printer halted. kill() called! July 31, 2015 03:50PM |
Re: Printer halted. kill() called! July 31, 2015 04:46PM |
madmike8
Do you have a heatbed? is the Thermistor configured in Marlin? Is it connected to the right pins? Also for your hotend thermistor. Do you have any other Thermistors configured in Marlin?
Re: Printer halted. kill() called! August 03, 2015 07:59PM |
Re: Printer halted. kill() called! August 03, 2015 08:03PM |
Re: Printer halted. kill() called! August 03, 2015 08:36PM |
Re: Printer halted. kill() called! August 04, 2015 01:08AM |
Re: Printer halted. kill() called! August 04, 2015 02:53PM |
tadawson
When a circuit is powered, ohmmeter readings are not valid . . . not certain exactly how you are making the determination of pin 41being grounded when the Arduinomis powered. There should be a pullup resistor on that pin high until the kill switch pulls it down by connecting to ground . . . and I think that pullup *should* be on the Arduino . . . For now, you should be able to redefine KILL_PIN to -1 instead of 41 to keep the printer operational while you figure this out.
- Tim
Re: Printer halted. kill() called! August 04, 2015 09:01PM |
Re: Printer halted. kill() called! February 03, 2017 04:00PM |
Re: Printer halted. kill() called! November 17, 2021 08:43AM |
