Hi all,
I'm adding a proximity sensor for Z min.
it is a DC6-36V PNP NC 4mm Unshielded Inductive Proximity Switch LJ12A3-4-Z/AY
the signal wire reads 12 volts when the sensor is NOT triggered. 0volts when triggered.
I have z min endstop inverting set to false and the pullup resistor is NOT defined.
when I use m119 in repetier, if NOT triggered, it reads TRIGGERED, and when triggered, it reads OPEN.
how do I change this?
I have tried inverting the endstop, but when I do that it always reads open.
any help would be greatly appreciated.
thanks.
