REPRAP full graphic LCD issue need help. August 29, 2015 07:37AM |
Re: REPRAP full graphic LCD issue need help. August 31, 2015 03:20PM |
#include #ifndef CONFIGURATION_H #define CONFIGURATION_H #include "boards.h"
//LCD and SD support #define ULTRA_LCD //general LCD support, also 16x2 #define DOGLCD // Support for SPI LCD 128x64 (Controller ST7565R graphic Display Family) #define SDSUPPORT // Enable SD Card Support in Hardware Console //#define SDSLOW // Use slower SD transfer mode (not normally needed - uncomment if you're getting volume init error) //#define SD_CHECK_AND_RETRY // Use CRC checks and retries on the SD communication //#define ENCODER_PULSES_PER_STEP 1 // Increase if you have a high resolution encoder //#define ENCODER_STEPS_PER_MENU_ITEM 5 // Set according to ENCODER_PULSES_PER_STEP or your liking //#define ULTIMAKERCONTROLLER //as available from the Ultimaker online store. //#define ULTIPANEL //the UltiPanel as on Thingiverse //#define LCD_FEEDBACK_FREQUENCY_HZ 1000 // this is the tone frequency the buzzer plays when on UI feedback. ie Screen Click //#define LCD_FEEDBACK_FREQUENCY_DURATION_MS 100 // the duration the buzzer plays the UI feedback sound. ie Screen Click // The MaKr3d Makr-Panel with graphic controller and SD support // [reprap.org] //#define MAKRPANEL // The RepRapDiscount Smart Controller (white PC // [reprap.org] //#define REPRAP_DISCOUNT_SMART_CONTROLLER // The GADGETS3D G3D LCD/SD Controller (blue PC // [reprap.org] //#define G3D_PANEL // The RepRapDiscount FULL GRAPHIC Smart Controller (quadratic white PC // [reprap.org] // // ==> REMEMBER TO INSTALL U8glib to your ARDUINO library folder: [code.google.com] #define REPRAP_DISCOUNT_FULL_GRAPHIC_SMART_CONTROLLER
Re: REPRAP full graphic LCD issue need help. September 23, 2015 09:52AM |
Not too sure what I was meant to try, but when I put in the #include bit I got a fatal error. So that won't work, not sure what I was meant to do with the second bit. But I had already uncommented the reprapdiscount full graphics bit. could you elaborate?Quote
Shogun
try this
Re: REPRAP full graphic LCD issue need help. September 24, 2015 10:35PM |
Re: REPRAP full graphic LCD issue need help. September 25, 2015 04:15AM |
Re: REPRAP full graphic LCD issue need help. September 25, 2015 09:08AM |
The seller that I purchased this LCD from sent it to me in a poly postal bag with no bubble wrap or anykind of protection so that would not surprise me if some thing was damaged the SD slot was a bit mashed. Is there anyway to test it to be for sure?Quote
o_lampe
Sounds like your LCD-encoder switch is damaged.
What Shogun tried to tell you is #include U8glib.h, but the forum software doesn´t allow those brackets... #see attached pic
-Olaf
