So, after two years of saving my pennies, matching parts, and spending an hour a month assembling, I am within striking distance of getting my first 3d up and running. (a Mendel i2, Arduino Mega2650, RAMPS 1.4, Marlin)
Last week, I finished the general assembly, and started running through the paces, testing everything to get ready for a test print. The LCD is up, SD card reading, and rotary control is registering. Also, the X, Y, and Z axies are all working beautifully. However, I can't seem get get any life out of E0.
I started troubleshooting by swinging the motor cable over to X. It works perfectly, so I know the motor and wiring are bang on.
Next, I tried swapping the A4988s between the E0 and X channels. X still running strong, and no life on E0.
This leaves me at either a bad E0 channel on the board, or a program error.
I am completely willing to believe a programing error, as I have hit a few bugs in setting this up that were the result of either my not knowing where settings lived, or Marlin having a bug or two of its own. However, if it's a bad E0 channel, I can chase code all day and get no where.
I wasn't seeing anything quite like this in the threads, so here I am, looking to the pros.
Question 1: Has anyone seen this particular issue before.
Question 2: If not, is there a way that I can change my set up to try using E1, instead of E0? This would help me test the code vs. hardware dilema.
Thanks in advance, everyone.
Edited 1 time(s). Last edit at 09/05/2015 06:38PM by BlackDragon.
