How to connect ramps1.4+arduino mega with Raspberry pi
September 18, 2015 05:57AM
Hello
can someone help me to connect a raspberry Pi on my printer?
I have arduino mega+ramps 1.4
I like to use octoprint and I was wondering if this is possible!
I also just bought this 3d scanner [www.achatzmediaserver.com] and I like to integrate into my printer!
As I understand a separate power supply for Raspberry is needed though it would be interesting to see if this system is feasible and especially if I can make it as possible integrated into the machine!
Edited 1 time(s). Last edit at 09/18/2015 05:58AM by mdcompositi.
Re: How to connect ramps1.4+arduino mega with Raspberry pi
September 18, 2015 08:02AM
You connect raspberry to arduino using an USB cable. Nothing Else.
You need a 5v power input for raspberry through it's mini USB port.
Edited 1 time(s). Last edit at 09/18/2015 08:03AM by dintid.
September 19, 2015 05:08AM
dintid
I need another power supply, or I can take the power from ramps??
September 20, 2015 04:36AM
mdcompositi
dintid
There is now 5V power on Ramps, it comes from arduino and is to weak for powering RasPI, too.
Wallwart 5V USB chargers are cheap, get one with the right USB-plug.
-Olaf
Edited 1 time(s). Last edit at 09/20/2015 04:36AM by o_lampe.
September 20, 2015 06:07AM
mdcompositi
dintid
You need a 5v wall-wart OR a step-Down to provide 5v to the Raspberry
The Rasberry can provide power to arduino through the USB plugs in the end of the Raspberry- Arduino only need like 0,2amps.
The Raspberry gets power through the mini-usb in the side-
The Rasberry connects to the Arduino through the "normal" USB-plugs (4 of them in Raspberyr Pi2) in the end of the Raspberry.
You do not want to power Raspberry in any way through the Ramps.
edited for clarification
Edited 3 time(s). Last edit at 09/20/2015 06:09AM by dintid.
September 20, 2015 03:03PM
This Video tells you exactly how to set up Octoprint.
Prusa i3 Rework - Ramps 1.4 - E3d Lite6 - Full Graphic LCD Controller
