what would be an upgrade to a ramps 1.4
January 10, 2016 05:16AM
Hi folks,
it might be a bit rude to ask in this forum but what would be an upgrade to the ramps/mega combo?
My ramps is working like a charm but I wouldn't mind having something that didn't need heaps of cooling,
replacing mosfets, replacing dodgy low amp power connectors, etc.
All help appreciated,
Andrew
Re: what would be an upgrade to a ramps 1.4
January 10, 2016 05:28AM
If you don't mind running different (and easier to configure) firmware, then Duet or Smoothieboard. Both are 32-bit boards with native USB interface, software-configurable stepper motor current, on-board A4982 drivers that are much better cooled than plug-in drivers, and good mosfets. Both are 24V-capable. Both have a built-in SD card socket. Both have an Ethernet port supporting a web interface, although the web interface on the Duet is much more advanced than the one on the Smoothie. The Duet has an on-board 5V switching regulator, and for the Smoothie you can buy one as an add-on.
Duet supports a colour touch-panel controller (full disclosure: I manufacture the display controller board for this) but not traditional monochrome LCD/encoder combos. Most Duet users just use the web interface.
The best Duet is the version 0.8.5 from Think3DPrint3D and supports dual extrusion You can get a cheap single-extrusion Duet 0.6 from Replikeo but the quality is variable.
There are also some closed-source Smoothie clones, but you are not doing the Smoothie developers any favours if you buy them.
Edited 1 time(s). Last edit at 01/10/2016 05:31AM by dc42.
Re: what would be an upgrade to a ramps 1.4 SOLVED
January 19, 2016 05:25AM
Thanks dc42.
The price tag is a bit higher though
January 19, 2016 06:05PM
friarfish
Thanks dc42.
True, but you get a lot more in return!
