Question: Low voltage on Heat Bed terminals?
Posted by jbg92
January 13, 2016 07:02PM
Hello everyone;
Printer: 3Up V2
RAMPS 1.4 board
I'm trying to troubleshoot what I think might be a problem with my heated bed: The bed heats well to about 60c, then from 60 to the target of 65 it takes about 30 minutes. I have 12v going into the board, but the voltage taken at the Heat Bed terminals is pulsing between 3 and 4 volts.
Is this normal? If not, any ideas on what I should do next?
Thanks in advance;
Joe
Re: Question: Low voltage on Heat Bed terminals?
January 13, 2016 11:24PM
So if I understand correctly the voltage read from the D8 output of the RAMPS is 3-4 volts? If your meter is reading that correctly than yes you have a problem. Your output should hover at around 12v at the bed. I'm not too familiar the electronics of the RAMPS but it sounds to be a blown MOSFET assuming it is receiving 12v
Prusa i3 Rework - Ramps 1.4 - E3d Lite6 - Full Graphic LCD Controller
January 15, 2016 04:10AM
It might be voltage loss across the wires, when you measure 3-4V directly at the heatbed solder joints.
If it's 3-4V at the Ramps terminals, check your 5V regulator of the ATMega. It might not provide 5V, so the MOSFET doesn't switch ON fully. ( FET gets very hot then! )
January 17, 2016 10:17PM
Thanks for the replies.
I'm still a newbie, but after messing around a little more I think it might have something to do with my software settings versus a hardware problem. I think I need to experiment a little more before I start changing parts out.
Appreciate the advice!
