Touch screen
January 16, 2016 11:51AM
Is it possible to connect a touch screen LCD to a ramps 1.4
If so did it run the encoder ?
Re: Touch screen
January 17, 2016 02:35AM
Repetier firmware now supports the PanelDue colour touch screen, so I guess the answer is probably yes, although I don't know if anyone has tried it yet.
Re: Touch screen
January 19, 2016 04:08PM
DC42, I just upgraded the paneldue firmware to 1.13. I noticed when I first boot up the screen of the PanelDUE there are 4 icons. Home, Y Home, Z Home and X home. However, once the system starts up, 3 Icons disappear and only the Home icon is left. How do I get the icons back?
Re: Touch screen
January 19, 2016 06:02PM
Your firmware appears to be reporting to PanelDue that it is configured as a delta printer. If it isn't then I suggest you raise the issue with the devs of whatever firmware you are using.
You can check what the firmware on your controller board is reporting by sending M408 S3 to the board from your PC and looking for the 'geometry' field in the response.
Re: Touch screen
January 19, 2016 06:04PM
dc42
Oops sorry. I am using Duet 0.6. Kossel Mini
Firmware Name: RepRapFirmware
Firmware Version: 1.09r-dc42 (2016-01-16)
Web Interface Version: HTML: 1.08, JS: 1.08
Web Interface by Christian Hammacher
Licensed under the terms of the GPL v2
