Ramps 1.4 and marlin PLEASE help
Posted by soso2
June 01, 2016 07:52AM
Hello
I'm very new to the 3d printing, and ramps
I trying to set up my ramps and full graphic smart controller, and keep getting error in Arduino 1.6.9 I copy it here what it looks like Please help
Arduino: 1.6.9 (Windows 10), Board: "Arduino/Genuino Mega or Mega 2560, ATmega2560 (Mega 2560)"
Marlin:1117: error: operator '>' has no left operand
#if (Y_MAX_PIN > -1
In file included from sketch\Marlin.h:24:0,
from C:\Users\HP 15\Downloads\files\FrankenCube\Dans-Cube2-Marlin-V1-Conversion-firmware\Marlin\Marlin.ino:29:
pins.h:309: error: pasting "/* Beeper on AUX-4*/" and "_RPORT" does not give a valid preprocessing token
#define BEEPER 33 // Beeper on AUX-4
sketch\fastio.h:45:44: note: in definition of macro '_WRITE'
#define _WRITE(IO, v) do { if (&(DIO ## IO ## _RPORT) >= (uint8_t *)0x100) {_WRITE_C(IO, v); } else {_WRITE_NC(IO, v); }; } while (0)
C:\Users\HP 15\Downloads\files\FrankenCube\Dans-Cube2-Marlin-V1-Conversion-firmware\Marlin\ultralcd.ino:141:3: note: in expansion of macro 'WRITE'
WRITE(BEEPER,HIGH);
C:\Users\HP 15\Downloads\files\FrankenCube\Dans-Cube2-Marlin-V1-Conversion-firmware\Marlin\ultralcd.ino:141:9: note: in expansion of macro 'BEEPER'
WRITE(BEEPER,HIGH);
pins.h:309: error: pasting "/* Beeper on AUX-4*/" and "_WPORT" does not give a valid preprocessing token
sketch\fastio.h:34:51: note: in definition of macro '_WRITE_C'
{DIO ## IO ## _WPORT |= MASK(DIO ## IO ## _PIN); }\
sketch\fastio.h:68:23: note: in expansion of macro '_WRITE'
#define WRITE(IO, v) _WRITE(IO, v)
WRITE(BEEPER,HIGH);
WRITE(BEEPER,HIGH);
pins.h:309: error: pasting "/* Beeper on AUX-4*/" and "_PIN" does not give a valid preprocessing token
sketch\fastio.h:34:79: note: in definition of macro '_WRITE_C'
WRITE(BEEPER,HIGH);
WRITE(BEEPER,HIGH);
sketch\fastio.h:39:51: note: in definition of macro '_WRITE_C'
{DIO ## IO ## _WPORT &= ~MASK(DIO ## IO ## _PIN); }\
WRITE(BEEPER,HIGH);
WRITE(BEEPER,HIGH);
sketch\fastio.h:39:80: note: in definition of macro '_WRITE_C'
WRITE(BEEPER,HIGH);
WRITE(BEEPER,HIGH);
sketch\fastio.h:30:48: note: in definition of macro '_WRITE_NC'
#define _WRITE_NC(IO, v) do { if (v) {DIO ## IO ## _WPORT |= MASK(DIO ## IO ## _PIN); } else {DIO ## IO ## _WPORT &= ~MASK(DIO ## IO ## _PIN); }; } while (0)
WRITE(BEEPER,HIGH);
WRITE(BEEPER,HIGH);
sketch\fastio.h:30:76: note: in definition of macro '_WRITE_NC'
WRITE(BEEPER,HIGH);
WRITE(BEEPER,HIGH);
sketch\fastio.h:30:105: note: in definition of macro '_WRITE_NC'
WRITE(BEEPER,HIGH);
WRITE(BEEPER,HIGH);
sketch\fastio.h:30:134: note: in definition of macro '_WRITE_NC'
WRITE(BEEPER,HIGH);
WRITE(BEEPER,HIGH);
C:\Users\HP 15\Downloads\files\FrankenCube\Dans-Cube2-Marlin-V1-Conversion-firmware\Marlin\ultralcd.ino:143:3: note: in expansion of macro 'WRITE'
WRITE(BEEPER,LOW);
C:\Users\HP 15\Downloads\files\FrankenCube\Dans-Cube2-Marlin-V1-Conversion-firmware\Marlin\ultralcd.ino:143:9: note: in expansion of macro 'BEEPER'
WRITE(BEEPER,LOW);
WRITE(BEEPER,LOW);
WRITE(BEEPER,LOW);
WRITE(BEEPER,LOW);
WRITE(BEEPER,LOW);
WRITE(BEEPER,LOW);
WRITE(BEEPER,LOW);
WRITE(BEEPER,LOW);
WRITE(BEEPER,LOW);
WRITE(BEEPER,LOW);
WRITE(BEEPER,LOW);
WRITE(BEEPER,LOW);
WRITE(BEEPER,LOW);
WRITE(BEEPER,LOW);
WRITE(BEEPER,LOW);
WRITE(BEEPER,LOW);
WRITE(BEEPER,LOW);
C:\Users\HP 15\Downloads\files\FrankenCube\Dans-Cube2-Marlin-V1-Conversion-firmware\Marlin\ultralcd.ino:159:3: note: in expansion of macro 'WRITE'
WRITE(BEEPER,HIGH);
C:\Users\HP 15\Downloads\files\FrankenCube\Dans-Cube2-Marlin-V1-Conversion-firmware\Marlin\ultralcd.ino:159:9: note: in expansion of macro 'BEEPER'
WRITE(BEEPER,HIGH);
WRITE(BEEPER,HIGH);
WRITE(BEEPER,HIGH);
WRITE(BEEPER,HIGH);
WRITE(BEEPER,HIGH);
WRITE(BEEPER,HIGH);
WRITE(BEEPER,HIGH);
WRITE(BEEPER,HIGH);
WRITE(BEEPER,HIGH);
WRITE(BEEPER,HIGH);
WRITE(BEEPER,HIGH);
WRITE(BEEPER,HIGH);
WRITE(BEEPER,HIGH);
WRITE(BEEPER,HIGH);
WRITE(BEEPER,HIGH);
WRITE(BEEPER,HIGH);
WRITE(BEEPER,HIGH);
C:\Users\HP 15\Downloads\files\FrankenCube\Dans-Cube2-Marlin-V1-Conversion-firmware\Marlin\ultralcd.ino:161:3: note: in expansion of macro 'WRITE'
WRITE(BEEPER,LOW);
C:\Users\HP 15\Downloads\files\FrankenCube\Dans-Cube2-Marlin-V1-Conversion-firmware\Marlin\ultralcd.ino:161:9: note: in expansion of macro 'BEEPER'
WRITE(BEEPER,LOW);
WRITE(BEEPER,LOW);
WRITE(BEEPER,LOW);
WRITE(BEEPER,LOW);
WRITE(BEEPER,LOW);
WRITE(BEEPER,LOW);
WRITE(BEEPER,LOW);
WRITE(BEEPER,LOW);
WRITE(BEEPER,LOW);
WRITE(BEEPER,LOW);
WRITE(BEEPER,LOW);
WRITE(BEEPER,LOW);
WRITE(BEEPER,LOW);
WRITE(BEEPER,LOW);
WRITE(BEEPER,LOW);
WRITE(BEEPER,LOW);
WRITE(BEEPER,LOW);
pins.h:321: error: pasting "/*the click*/" and "_RPORT" does not give a valid preprocessing token
#define BTN_ENC 31 //the click
C:\Users\HP 15\Downloads\files\FrankenCube\Dans-Cube2-Marlin-V1-Conversion-firmware\Marlin\ultralcd.ino:211:5: note: in expansion of macro 'WRITE'
WRITE(BTN_ENC,HIGH);
C:\Users\HP 15\Downloads\files\FrankenCube\Dans-Cube2-Marlin-V1-Conversion-firmware\Marlin\ultralcd.ino:211:11: note: in expansion of macro 'BTN_ENC'
pins.h:321: error: pasting "/*the click*/" and "_WPORT" does not give a valid preprocessing token
pins.h:321: error: pasting "/*the click*/" and "_PIN" does not give a valid preprocessing token
sketch\fastio.h:26:34: note: in definition of macro '_READ'
#define _READ(IO) ((bool)(DIO ## IO ## _RPORT & MASK(DIO ## IO ## _PIN)))
C:\Users\HP 15\Downloads\files\FrankenCube\Dans-Cube2-Marlin-V1-Conversion-firmware\Marlin\ultralcd.ino:236:31: note: in expansion of macro 'READ'
if((blocking' has no left operand
This report would have more information with
"Show verbose output during compilation"
option enabled in File -> Preferences.
[Solved] Ramps 1.4 and marlin PLEASE help
June 05, 2016 11:44AM
Solved by changing firmware
Edited 1 time(s). Last edit at 06/05/2016 11:49AM by soso2.
