USB power only axis not moving?
Posted by soso2
June 05, 2016 02:09PM
Hey everyone
When you have the ramps connected to the pc, with just usb power.. and connected to Pronterface, and I asking the printer to move the x axis to the right 10mm, but it doesn't move??
Ramps board connects to pronterface with correct braud rate,. Says connected with no errors..
Now when I connect ramps to the power supply and ask x-axis to move it does.. Not connected to pc, just power supply, using firmware.
Also I read there supposed to be a red led when connected through usb, I don't get a red led..
Edited 1 time(s). Last edit at 06/05/2016 02:10PM by soso2.
Re: USB power only axis not moving?
June 05, 2016 08:50PM
You cannot run a ramps just off of usb.
USB only supplies 5v to logic side of board, steppers need 12v to move.
[SOLVED] USB power only axis not moving?
June 06, 2016 08:21AM
Thanks Dust
Yeah this is my first DIY 3d printer, I thought .you just wire it up, and you good to go.. I was wrong.. big time.. Thanks..
