Mega2560 / Prusa - via standard serial port?
Posted by jrherita
June 12, 2016 06:46PM
Hi Folks!
I have an 'old' computer that I wanted to connect to a Reprap via a standard serial port.
I have a Prusa i3 (and an older i2) I believe running Sprinter firmware (it may be Marlin - it's been a while), RAMPS 1.3/1.4, and the Mega 2560.
Since the old computer doesn't have USB - can I just connect to the serial pins on the Mega 2560 to send commands (/ receive ACK)? or do I need to do something with the firmware or otherwise to tell it to use serial instead of USB communications.
Thanks!
John H
Re: Mega2560 / Prusa - via standard serial port?
June 12, 2016 07:26PM
computer serial is -12v and +12v
arduino mega serial is 0 and +5 volts
You need a hardware converter that converts the voltages (max232 or something similar)
The converter can just be plugged into AUX-1 PIN D0 and D1 are also knows as TXD0 ad RXD0, the serial inputs to the mega.
No firmware modifications are required.
