[SOLVED]Ramps 1.4 connecting but unresponsive motors July 31, 2016 04:06AM |
Re: Ramps 1.4 connecting but unresponsive motors July 31, 2016 05:38AM |
Re: Ramps 1.4 connecting but unresponsive motors July 31, 2016 09:27AM |
All endstops work fine (3 endstops and the probe), I'm going to check if the driver chips get any current asap!Quote
o_lampe
Did you check your endstops? Might be a stuck switch that keeps the motors from moving?
You could also check the voltage between Vmot/GND pins on the driver chips.
Re: Ramps 1.4 connecting but unresponsive motors July 31, 2016 04:13PM |
Re: Ramps 1.4 connecting but unresponsive motors August 01, 2016 09:27AM |
Re: Ramps 1.4 connecting but unresponsive motors August 01, 2016 02:10PM |
o_lampe
That leads me to the idea, you might have wrong EEprom Settings or the Eeprom chip died.
You wrote, you've flashed the latest Firmware to be sure, but did you send "M502" and "M500" afterwards to refresh the Eeprom?
Also try M503 to see, if anything is wrong with the Eeprom.
