A clone Arduino Mega lost USB connection. August 08, 2016 09:36AM |
$ lsusb Bus 007 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 006 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 001 Device 005: ID 050d:706a Belkin Components 2-N-1 7-Port Hub (Upper half) Bus 001 Device 002: ID 050d:0706 Belkin Components 2-N-1 7-Port Hub (Lower half) Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 004 Device 003: ID 056a:0017 Wacom Co., Ltd CTE-450 [Bamboo Fun] Bus 004 Device 002: ID 04b4:0101 Cypress Semiconductor Corp. Keyboard/Hub Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Re: A clone Arduino Mega lost USB connection. August 08, 2016 06:14PM |
Re: A clone Arduino Mega lost USB connection. August 09, 2016 07:32AM |
Note: It's a shame that Mega 2560 R3 is Not that durable as Ramps 1.4 Board.
1. Unstable power supply, shortage on stepper driver or limit switch will cause problem to Mega 2560 R3
2. Can not burn latest firmware to it.
If the CPU is burnt, please drop the controller. 1117 power regulator or usb chip 16u2 problem, you may change the module to fix it. - See more at: [www.robotdigg.com]
